no spark
Old Mar 10, 2004 | 05:20 PM
comeonstart's Avatar
Angry no spark
OK, i bought a 79 base model at an auction. it was at night but the car appeared to be in good shape. anyway on the windshield it gave the diagnosis on what was wrong it said timing. I brought it home today and put my timign light on the 2nd upper plug wire-which was hooked to trailing on the distributor, I got a hit on this one with the light and found it to be way out of time. but i put it only the other 3 wires nothing happens, no hit on light. it works fine on the one-not others. any help?
Old Mar 10, 2004 | 08:25 PM
79rx's Avatar
I would change the points,cap,rotor,wires and plugs then go from there. When i got my 79 the points looked like they had 10,000 miles on them!
Old Mar 10, 2004 | 08:34 PM
plugs and wires are clean, one of the ingition boxes is clean, i file the rotor and cap for a clean surface. someone has been workin on it already. no unconnected wires. one wire in the distributor was soldered on and is loose so i am gonna fix it tomorrow to make sure thats not it but i am sure its gettins contact like it should.
Old Mar 10, 2004 | 09:26 PM
Rx7carl's Avatar
Airflow is my life
Whoa, ignition boxes? 79's had points. Maybe you got a car that someone upgraded with an 81-85 electronic ignition dizzy? Does it have 2 small ign boxes mounted on the dizzy body?
Also, yu check the ign timing off the front rotors plugs. Lower is leading, upper is trailing.
Old Mar 11, 2004 | 03:23 AM
Jeff20B's Avatar
Lapping = Fapping
Could it have been built in '79 and sold as an '80 model?
Old Mar 11, 2004 | 06:23 AM
Rx7carl's Avatar
Airflow is my life
Yea but didint 80's have one box remotely mounted on the strut tower? Not 2 seperate boxes, unless hes mistaken by saying boxes?
Old Mar 11, 2004 | 08:17 AM
well they are not boxes but they are mounted just behind the battery. they are cylinders. The plate inside the door says 9/78 so its a 79 model.
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
