Who uses a Moroso oil pan
And how do you like it?
Did you lengthen the oi pickup tube so it will draw oil from the bottom of the pan?
Any noticeable improvement? Any less oil starvation?
Moroso Oil Pans
Description: Mazda: 13B Rotary, 6.25 qt., dual trap door baffles, aluminum, oil pan
Part #: MOR-20942
Fits: Mazda RX-7 13B
Years: All
Designed for street performance machines that see occasional strip use, this Moroso oil pan is modified with a deep sump for increased capacity and is fully fabricated from aluminum with a billet 3/8 in. thick gasket rail. It features dual trap door baffles to direct oil flow, an .080 in. thick aluminum baffle plate to de-aerate and cool returning oil, and a magnetic drain plug. With a simple bolt-on installation this oil pan is perfect for your weekend warrior
http://www.prostreetonline.com/pso/p...tsku=MOR-20942
Moroso Oil Pans
Part #: MOR-20942
Years: All
I'm sure the stock pan is fine, but having 1.25 more qts of oil in there would be nice, bet it would help with oil cooling as well. Plus it looks cool, that always helps. I was considering getting the 12a version for my project, as the pan on there now is a rusty mess. I know FD racer has one on his car, hopefully he'll chime in.
Trending Topics
There is a 12A RX-7 pan:
http://moroso.com/catalog/categorydi...?CatCode=13316
I wish they had a 13B pan...
jose vidal @ www.mazdadragracing.com sells aluminum oil pan. give him a call and find out if this will fit the 1st gen chassis. Just ask for opinon.
sorry to bring this back from the dead guys, but I'm starting to collect pieces for an engine buildup (12a) and this is on my to get list, anyone else have any opinions/experiences with it?
summit and jegs both sell it for $235. Not a bad price considering what it is. Also, moroso's site claims it fits in the stock chassis, using stock pan gasket, pickup tube and dipstick. I'm tempted to buy it, would be a nice addition to my motor....
we got an aluminum pan on the race car....not sure how compares with stock one, have to look at my car. I'll take a pic of it tommorow and post. The reason a "deeper" pan doesn't like to fit is because of the steering arm thats behind the crossmember. Not sure if ours is moroso or what but i'll look and post tommorow.
more oil capacity, and my old pan is beat to **** like all of them seem to be. would just be a nice part to put on the engine. According to moroso's site in order to get the extra capacity the sides extend out, so there isn't a issue with steering clearance etc.
Originally Posted by DriveFast7
I've seen people use them here. Oil pan looks like it'll fit a 1st gen just fine!
I just sold one because it does not fit a 12a or my 13bT2. It is made for earlier applications.
They don't fit first gens - unless you modify the **** out of themn
Not worth it IMHO.
Mazdaspeed sells a high capacity 12a pan. I have the aluminum Mazdaspeed one in the racecar. It does not have trap doors.
I bought and installed the Moroso oil pan on my repu. It has two trap doors to route oil to and keep oil around the oil pickup tube. And 1.25 more quart capacity. Comes with a baffle plate. But that early 13b pan will not fit 1st gen: the steering and crossmember are in the way.
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
I bet those pans aren't cheap either (but sure are pretty)
