pop off valve... what is it?
Old Mar 8, 2004 | 08:54 AM
pugg57's Avatar
proper motoring
i've heard of pop-off valves (once or twice on this forum) and it sounds like an excellent way to avoid any boost spikes. i'm not saying to use it as a boost controller, just say... if i'm going to run at 11-12psi, i could adjust the pop-off for 13 that way, if anything happened and for some reason the stocker twins decided to push 20psi towards my intake, the pop-off would really the excess pressure... kinda like a fart i guess instead of blowing my engine. am i following the idea correctly here? anyone know of any good ones available on the market?
Old Mar 8, 2004 | 09:22 AM
Snook's Avatar
Tony Stewart Killer.
yeah you get it whats your question? I think greddy makes one im gonna get that one...the thing that sucks though is that 1 psi on our car can make the engine blow. So id run a little lower boost and set it for 12 if thats the max you can run on your setup
Old Mar 8, 2004 | 09:37 AM
pugg57's Avatar
proper motoring
ah... yeah i didn't really think about the sensitivity thing too well. i wasn't sure if i understood what they were used for. basically, was making sure i got the idea and if anyone would recommend one, or not using one at all. i'm pretty sure i'll be able to run 12psi on the stock fuel inj. with 95% duty but don't wanna push it that far. will see about setting it around 11.5 and having the pop off go at 11.75ish. GReddy you say though, anywhere i can find that for sale?
Old Mar 8, 2004 | 10:00 AM
XSTransAm's Avatar
Ee / Cpe
That is the idea behind a pop off valve. I woulldent trust that over a nice boost gauge with a big red light though. But i guess some will say every little bit helps.
edit: just noticed the double post
Old Mar 8, 2004 | 10:42 AM
pugg57's Avatar
proper motoring
i'm getting a PFC put in my car soon and will be using its monitor for the A/F ratio, boost, knock, etc.
Old Mar 8, 2004 | 10:46 AM
Snook's Avatar
this would have saved my engine since I boosted over 30psi instead of 16
http://www.greddy.com/products/produ...Relief%20Valve
Old Mar 8, 2004 | 12:11 PM
Scrub's Avatar
bow leggin'
I've got one that I never installed on my car. I'll sell it to you with the adapter plate for like $105 shipped. Never used it. It just an insurance thing. kinda like a secondary wastegate if you will.
Old Mar 9, 2004 | 07:47 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
i bought the greddy pop off after hearing about someone grenading their engine from a boost spike. the item is well built but after further investigation i decided not to use it. they can leak boost and pop off at varied pressures i am told. most have settled on adjusting their maps so as to run real rich on boost spikes.
howard coleman
Old Mar 9, 2004 | 08:49 AM
Snook's Avatar
you just have to make sure that you have enough injectors to do that. such as 1600s and that your map sensor can recognize the extra boost. the stock one reads to only 1.15 bar.
Old Mar 9, 2004 | 09:12 AM
WHIPSrx7's Avatar
DRFTRX7
Check this link out, a little explanation of it:
http://www.rx7.com/cgi-local/3catalog.cgi?cat=9&part=4
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
poop2003
Sep 21, 2015 10:28 PM
BUSTN
Sep 21, 2015 05:01 PM
