rpm limit-problem
Old Mar 6, 2004 | 08:42 PM
sedentaryelite's Avatar
Angry rpm limit-problem
Hello,
I own a completely stock 85 gsl-se with 83k miles. recently, the idle was not an idle but an 'up and down and die' if you know what i mean. it also had another annoying problem, that is it would, under load, not accelerate past 5000 and the engine's noise would change. i haven't tried to go over 5000 since it first happened b/c the engine noise sounded damaging/bad
yesterday a mechanic replaced two of the intake manifold gaskets and cleaned everythign in the fuel system, the filter, injectors, and tuned it up and everything. so now it purrs at 700 rpm steady.
but i still can't accelerate past 5k rpm. the car has no aftermarket ignition, no stock rpm limiter and under no load(clutch disengaged) i can rev as high as i'd like to.
whew.. i think i covered everything. any ideas?
Thanks
woodman
ps if you recall i asked about this before but this is sort of a new magnitude of a problem because the mechanic fixed everything that was suggested in my last thread about this.
edited for clarity
Old Mar 6, 2004 | 08:51 PM
BigJim's Avatar
trainwreck
Clogged cat would be my guess
Old Mar 6, 2004 | 08:58 PM
is the easiest fix for that to take it out and clean it or to get a new one?
pardon the ignorance
thanks
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
Einheri
Oct 7, 2015 12:23 PM
musker
Oct 1, 2015 05:58 PM
