starts then revs on its own
Old Feb 24, 2004 | 09:09 PM
Chamele03's Avatar
I swapped carberators tonight, ('81/3 - '79) i got everything hooked up, and got the vacum stuff hooked up using the tubing of the rats nest, and no selinoids, i didnt put the idle compensator on,( i even tryed with everything caped but the two ports for the ventelation thing, and it did this)
every time i start it, i have to give it a little gas while cranking, then the engine just goes full throtle.
i have all the vacum lines hooked up as they where on the other engine ('79 stock) except the selinoid on the passenger side of the carb is not connected to anything, I just capped it, I have been reading the haynes all night but cant find anything it might be
any ideas would be greatly appreciated
Old Feb 24, 2004 | 10:27 PM
nimrodTT's Avatar
all aboard!
Make sure the butterflies are closed at idle.
Old Feb 25, 2004 | 10:57 PM
Chamele03's Avatar
how do i do this, it wont idle, it just goes full throtle
Old Feb 25, 2004 | 11:01 PM
sa22c_Drifter's Avatar
Just close the butterflies when it starts. Mines had the same thing but vice versa. The butterflies were closed all the time.
Siraniko's Avatar
RX for fun
I havent worked on stock carbs/manifold in ages. but I will give this one a shot. turn the engine off. grab the throttle carble and put the carb on WOT so you can see if the butterlfy on the intake manifold is in closed position. close will result in high idle.
Old Feb 25, 2004 | 11:14 PM
Chamele03's Avatar
how can i fix this if this is the problem?
Old Feb 26, 2004 | 12:12 AM
Siraniko's Avatar
RX for fun
remove the carb and manifold from the engine. remove the 4 butterfly screws. then slide the butterfly out, then the shaft. fill in the holes in the intake manifold with jb weld.
Old Feb 26, 2004 | 03:06 PM
Rotor13B's Avatar
Wassup!!
Old Feb 27, 2004 | 04:56 PM
Chamele03's Avatar
progress?
the car only goes wot with the choke out, if i start it without the choke or push the choke in after it is started the car spuders and die, and if i give it gas it spuders and just barely stays running
any ides on why it might do this?
13
Jan 9, 2018 11:19 AM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
rx7shirley
Sep 2, 2015 02:11 PM
