New Pioneer Head Unit: poor reception
Old Feb 19, 2004 | 12:57 AM
edomund's Avatar
Bastardized RE AE
I have a 87 T2.
I just installed a new Pioneer DEH-P8500MP head Unit. I don't get AM reception at all and FM is OK.
I hooked up a signal amplifier and still no AM reception.
I have the head unit hooked up to the antenna connection with the male plug.
There is also a female plug I assume goes to the windshield antenna.
Which plug goes to which antenna and which one is for AM?
What should I do to get AM reception?
Thanks
Ed
Old Feb 19, 2004 | 01:17 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I think the front one is for AM?...
I asume you wired the rear one up right and it goes up?
Old Feb 19, 2004 | 01:49 AM
edomund's Avatar
Bastardized RE AE
Yeah it goes up.
I even tried an aftermarket antenna. No AM reception.
Anyone else have poor AM reception?
Old Feb 19, 2004 | 08:43 AM
Icemark's Avatar
The poor reception you are getting is from the antenna not having a ground. Are you using the stock power antenna or has it been replaced with something aftermarket?
Either way, you need to clean the mounting under the fender and re-mount the antenna.
At the same time, double check what you are using for ground on the radio. It should be to a bolt in the car... not to any wire found in the dash. It is common for (shall we say less experienced installers) to use the dash light Red/Black as ground, which will also give you problems.
Old Feb 19, 2004 | 02:01 PM
NZConvertible's Avatar
I'm a boost creep...
The two antennae are used for both AM and FM; the stock head unit would use whichever one gave the strongest signal.
Old Feb 20, 2004 | 07:55 PM
edomund's Avatar
Bastardized RE AE
For people searching with this problem, I figured it out.
The antenna wire that plugs into the head unit that runs to the back of the car where the antenna actually plugs in was no good.
I hooked the antenna straight up to the deck and it worked. So then I ran a new antenna extension from the head unit to the antenna and now I have perfect reception.
Ed
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
