Rebuilt Engine
Old Feb 18, 2004 | 12:47 PM
jdeez42's Avatar
Rebuilt Engine
Is there anywhere else besides RotaryRessurection.com that does this?
Old Feb 18, 2004 | 12:52 PM
Akabane's Avatar
i'd like to know as well heh my engine seals are almost done for theres pressure building somewhere and i've changed the thermostat the coolant is flowing in the radiator but pressure is building up where the thermostat is and heats up sometimes.
Old Feb 18, 2004 | 12:53 PM
hybridracer's Avatar
I Post In The Nude
Pineapple Racing
Marvelspeed
Mazdatrix
Gotham Racing
Theres lots of places. Do a search and youll find more than what I just listed. And check out the CA local section and ask for someone local to you.
Old Feb 18, 2004 | 01:40 PM
Bukwild's Avatar
Jdeez42 and Akabane I have gone through Kevin at RR. He is who you want to go through trust me. Also compare his prices and warrantee. Best in the busniess.
He built me a t2 motor and did the swap in my vert with excellent work. Now he is milling out the rotors for 3mm apex seals from rotary aviation "best you can get". Now we are installing a haltech/FMIC/ and a borg warner turbo setup for 400hp to the wheels. Its up to you.
Old Feb 18, 2004 | 01:41 PM
Akabane's Avatar
awesome i had just called r and r they said they can do the job for 1700-2000 what do they do for rebuilds besides replacing seals and springs?
Old Feb 19, 2004 | 06:29 AM
crickifur's Avatar
atkins rotary
Old Feb 19, 2004 | 08:52 AM
Icemark's Avatar
I recommend Kevin at Rotary Resurection, but I understand you can also buy a remanufactured motor from Mazda right now for around $2200
Old Feb 19, 2004 | 09:24 AM
BigTone's Avatar
I would look around for someone close to you, that way in case you have a problem you will have an easier time dealing with it.
Ciclovnz
Oct 18, 2015 03:04 PM
ncds_fc
Aug 15, 2015 10:06 AM
