Drove the Yello Rocket around....
Old Oct 22, 2001 | 01:28 PM
cymfc3s's Avatar
I Raise Chickens
This sunday i took the little yellow one out for a drive. For some reason, she doesnt like the start cold, but hot starts fine. I think she forgot that t2's are supposed to start cold, but flood out when hot. Oh well. I think its not happy that im using a probeGT air flow meter. But it drives really nice, cruises great, lots of low end power. It revs to 4k no problem. I drove it around a bit, then checked the codes. Im getting a crank angle sensor code and an oil metering pump code. I figured id be getting an oil metering code, im using an 87-88 mechanical pump. I checked the crank angle sensor, connector is ok. I reset the codes and drove it around some more. Still getting same codes. I need to track the wiring on the harness and see about that crank angle sensor code. Might need to replace the CAS. Other than that, the car is running really well. It idles silky smooth even with enlarged ports. Ill probably take it for a spin in a couple of weeks after i get done moving into the new house. Anyone wanna cruise??? =]
Old Oct 22, 2001 | 01:38 PM
RXTASY1's Avatar
Sure! Come up to Idaho, and I will cruise with ya!
That is a very nice looking ride you have built!
Old Oct 22, 2001 | 03:18 PM
gnat's-ass7's Avatar
Make that two...
Count me in...
Old Oct 22, 2001 | 03:23 PM
snoopster76's Avatar
Twisted Girl Chaser
add a third
of course all things pending, but you can count me in.:1party:
Old Oct 22, 2001 | 06:24 PM
Mazda2ndgen's Avatar
probe Gt AFM? advantages to doing this? wiring issues?
Old Oct 22, 2001 | 06:38 PM
cymfc3s's Avatar
I Raise Chickens
advantages are: ProbeGT airflow meter was located on top box of misc parts. TurboII airflow meter was not located after many many hours of ripping apart the garage.
Old Oct 22, 2001 | 06:57 PM
13BAce's Avatar
On a long vacation
Weren't you going to go with an E6K?
Old Oct 22, 2001 | 07:03 PM
cymfc3s's Avatar
I Raise Chickens
I still am. Im moving so i need to move the car to the new house. So i had to throw everything together and get it running with the stock ecu. I thought it would barely run, but its actualy running really well right now. When i get the car to the new house i can start wiring up the new harness for the e6k.
Old Oct 22, 2001 | 07:07 PM
Rx_treme's Avatar
yeah Haltechs are badass , i'll cruise wit ya.
Jason
~~~~~~~~~~~~~~~ 86 GXL ~~~~~~~~~~~~~~~~
~Series 4 J-Spec ~Haltech E6K ~Apexi N1 Dual
~2.5" Down Pipe ~2.5" Straight Pipe ~Bonez Intake
~3" TID ~AVC-R ~Perma Cool 16" E.Fan ~8mm Wires
~Blue silicon lines ~TB mod ~TB Polished ~No Emissions
~GReddy A/F w/ 4 wire o2 ~Whole Exhuast Thermowrapped
~Tokico Illumina 5 ways ~HKS Super Form Springs
~17" Konig J-specs ~245/45/17 Kuhmos ~T2 Tranny/Clutch
~Phoenix Gold Stereo ~Recaro Race Seats ~Debadged
~Tinted Windows ~New paint ~2700 lbs.
--------In the mail-----------
~Blitz Super Sound BOV ~HKS POV
~Turbonetics T04b, H-Trim, P backside, .69 A/R
~Walbro Pump ~800cc Secondaries
--------Up Next-----------
~Racing Beat Sways ~Strut Tower Bars
~Camber Plates ~Camber Links
Old Oct 22, 2001 | 08:01 PM
hahah, very good reason!
Old Oct 22, 2001 | 08:46 PM
13BAce's Avatar
On a long vacation
That's what I figured. I was just making sure you weren't wimping out. Are you using the fully terminated harness? If so then all you'll need from your engine harness is the water temperature gauge sensor and the windshield wiper harness. That took me a LONG time to do.
Old Oct 22, 2001 | 09:10 PM
Rx_treme's Avatar
i didnt need the temp gauge plug.....
all i needed was the alternator plug,
the cruise control plug,
and the wiper motor plug,
hmm and my water temp gauge still works..?!?
Jason
Old Oct 22, 2001 | 09:38 PM
13BAce's Avatar
On a long vacation
Jason
On my harness--91 TII--the water temperature sensor was part of the engine harness.
Old Oct 23, 2001 | 12:46 AM
Rotary Racer's Avatar
Zoom Zoom Boooom
Probe MAF, not starting when it is cold? Why don’t you stop rigging your **** and fix it proper!! Patience is a virtue and my friend you need some!! Haha I will ride in your car when it is not rig-a-fied. Late
Old Oct 23, 2001 | 03:05 AM
Mazdarules's Avatar
doesn't the oil metering pump code make the ecu go into "limp home mode?" on the 89-91 cars.
Old Oct 23, 2001 | 10:25 AM
Rx_treme's Avatar
oh 91 that explains it, are you going to wire the OMP into the Haltech?
jason
Old Oct 23, 2001 | 12:17 PM
13BAce's Avatar
On a long vacation
If you add some resistors I think it will work ok, unless the ECU needs to see a variable resistance.
Old Oct 23, 2001 | 12:36 PM
cymfc3s's Avatar
I Raise Chickens
Yah, the ecu should go into limp home mode, but so far it hasnt. Even if you throw some resistors, im still no sure if it will work. The ecu wants to see the metering pump motor spinning. So far, it hasnt been too pissed off that its not there.
For those of you wondering why im using an 87-88 front cover and mechanical OMP, its because the haltech doesnt control the oil metering. A much easier solution is to pre-mix.
Old Oct 23, 2001 | 03:12 PM
13BAce's Avatar
On a long vacation
I premix with my Wolf 3D. It only takes an extra 2 minutes at each fill-up.
ls1swap
Jun 3, 2024 03:25 PM
Aramir
Oct 18, 2015 02:39 AM
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
