Sponsored by: CARiD
Engine front hub and roller barring
Old Feb 14, 2004 | 10:20 PM
J.S.J's Avatar
I got my engine back from the builder but he didn't install the front engine hub? I know about the roller barring inside the front cover and how important it is to keep it in place. My dilemma is, I installed the hub and rotated the engine on the stand and felt it drop down a small amount so it seated something also I understand the hub protrusion behind the "E" shaft should not exceed around 240 mm or there is a problem with the thrust barring/roller barring. The measurement is hard to make from within the hub and it looks like its still over 240 mm is there a way to get the thrust/needle barring to slip back. Does anyone have some ideas to offer up while doing this project. I am not sure the rollers are incorrectly.
Old Feb 16, 2004 | 10:30 PM
black_sunshine's Avatar
It's a very simple solution. Take the front cover off and install the "stack" correctly. Don't guess or take shots in the dark; doing so will only lead to more problems. Do it right the first time, and prevent problems down the road.
FD7KiD
15
Feb 26, 2021 10:12 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
FD7KiD
Aug 17, 2015 11:50 PM
