dual pulley
Old Feb 12, 2004 | 06:37 PM
Junia's Avatar
Uchinanchu
dual pulley
I don't know if anyone here knows this, but I've been running a dual pulley on my altenator for over a year now but I didn't have to pay the usual amount that most people pay for one. All I did was get one off of a 1984 dodge caravan with the 2.2 liter engine. The pulley fits nice with no modifications needed. Just wanted to let you guys know just incase you didn' t know already.
Old Feb 12, 2004 | 06:39 PM
Lotus00's Avatar
sweet, but is it the right diamiter? (wouldnt want to over-drive the alternator)
Old Feb 12, 2004 | 07:44 PM
seein7s's Avatar
i have same pulley and it has been on my car with the stock alt for about 40000 miles. still going
Old Feb 12, 2004 | 07:50 PM
nelam's Avatar
Which pulley on the Caravan? Crank? Alt? Powersteering?
Thanks
Nelson
Old Feb 12, 2004 | 07:52 PM
Glazedham42's Avatar
Resurrecting Gus
You have a pic of what this pulley looks like? An 84 Van might be kinda rare also. Do you know if it came on any other years beside the 84? My local parts yard is pretty small and if it's not in high demand they crush it. Would this pulley be on any 2.2 dodge motor from the 80's? ANYBODY KNOW???
Old Feb 12, 2004 | 08:09 PM
peejay's Avatar
Old [Sch|F]ool
Dual pulleys are not necessary if you either:
Keep the air pump
or
Trash the water pump-driven fan in favor of an electric
Option #1 maintains positive belt drive on the water pump because the alternator belt only glances off of the water pump pulley, and it does so from the untensioned side. Option #2 goes to the root of the problem and eliminates the main load on the water pump pulley.
Go for option #2. It's sooooooo much better. Hell, even if you still hav an air pump, go for #2.
Old Feb 12, 2004 | 08:34 PM
Lotus00's Avatar
I dont have an air pump, or fan and i still get some belt slippage. I have made sure the belt is tight, and it was (it has always sliped) new.
Ill be going to the junk yard to find me one of the pullies!
Old Feb 13, 2004 | 12:34 AM
Cody's Avatar
SKELETOR!
Yeah, but then you don't get the BLING BLING of my Higgi pulley...
Old Feb 13, 2004 | 02:34 AM
Junia's Avatar
Uchinanchu
its the alt pulley off of thats on the 2.2 liter engine. Its the same diameter and everything and I've been running it and my friends have been running them longer than I have. I don't know if they came on any other dodges but, I'm pretty sure you can find a dodge/chrysler caravan in the junkyard because when I went and got mine there were about 5 or 6 there. Not all of them had the right motor though.
Old May 24, 2004 | 01:30 PM
cpt_gloval's Avatar
KARATE EXPLOSION
anyone know if you can get the part at napa or whatever - and if so, how much does it cost?
Old May 24, 2004 | 02:25 PM
Kill No Cone's Avatar
There has been a thread on this in the past with part numbers and everything.
Old May 24, 2004 | 04:15 PM
Metallic_rock's Avatar
Ride 'n Style
The pulley is available on Dodge caravans with the Mitsubishi engine (and alternator).
I pulled the whole Alternator off and used it with the pulley. (you can swap out the pulley too... it's the same diameter.) The alternator is 75 amp and plugs right into the stock FB wiring.
I've seen this alt in 86-89 Dodge Caravans. Most Junk yards only charge 8-10 bucks for an alt.
Old May 24, 2004 | 04:16 PM
Ride 'n Style
NOTE: The above post said 75 AMP!!! That's why I decided to go ahead and use the whole alt... you do have to notch your alt. mount so your dizzy can still turn. It's an easy 1 hr job, max.
Old May 24, 2004 | 04:20 PM
cpt_gloval's Avatar
KARATE EXPLOSION
is there a reason to use a 75amp alternator if i won't be running any special lights or stereo?
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Robrods64
Oct 2, 2015 07:56 PM
