oh no. need help please
Old Jan 31, 2004 | 01:56 PM
Can some one please help me? This morning i was charging the car battery ( I have a 85 gsl) and when i went in the car to turn the car on, some thing in the engine compartment made a "poof" so i poped the hood and nothing was wrong. then i tryed to start it again and the starter dident turn, and the dash lights dident even go on, and the interior lights dident work either. I checked the fuses and they are all good. What could be wrong? Please help me.
Old Jan 31, 2004 | 01:57 PM
wwilliam54's Avatar
it WILL run
fusible link
Old Jan 31, 2004 | 03:27 PM
what or where is the "fusible link?"
Old Jan 31, 2004 | 03:42 PM
mazdaverx713b's Avatar
Have RX-7, will restore
there is a brown "block" near the battery that houses the links. you will have 3 links if you have a 12A and 5 if you have a gsl-se.
Old Jan 31, 2004 | 03:47 PM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
elaborate on the poof, was there smoke?
Surely you checked batt connections.
Old Jan 31, 2004 | 04:23 PM
ok i checked the box and all the links are connected and is still wont do anything. when i tryed to start it a poof came from the hood no smoke no nothing it was not loud at all either.
Edit: Oh yeah i even replaced the connetions that connect to the battery so i know its not the battery and the headlights will turn one but they will not flip back down.
Old Jan 31, 2004 | 04:26 PM
one of the links may have burnt p on the inside, not showing its defect from the outside.
Old Jan 31, 2004 | 05:39 PM
"one of the links may have burnt p on the inside, not showing its defect from the outside."
yep that was what was wrong, THANK YOU GUYS VERY VERY VERY MUCH!
Old Jan 31, 2004 | 05:41 PM
any time dude. good luck with the car
Old Jan 31, 2004 | 05:55 PM
CARLiTO_'s Avatar
maybe u connected the neg to the pos and pos to the neg
Old Jan 31, 2004 | 06:38 PM
Lotus00's Avatar
Check or replace the big wires from the battery to the starter. Maybe your ground wire cracked or something... they are cheap aluminum and crack very easily when they get old.
I know this dosent have anything to do with the poof, but my car had these same symtoms (minus the poof) and replacing the wires did the trick.
Old Jan 31, 2004 | 06:40 PM
Lotus00's Avatar
oh, and dont yell at me when im wrong
Old Jan 31, 2004 | 09:22 PM
wwilliam54's Avatar
it WILL run
Old Jan 31, 2004 | 11:48 PM
bliffle's Avatar
Damn fusible links are a problem, but you can get appropriate wire at Kragens (and, I suppose, any other auto store). Carry a few scraps in your glovebox, along with spare ignitors and fuses.
B
Old Feb 1, 2004 | 02:49 AM
cdrad51's Avatar
Lorem ipsum dolor sit ame
I must be blessed. 2 years with my car and haven't had any electrical problems at all. Not even a fuse I've had to replace.
Edit: Knock on wood!
jjandros
Aug 28, 2015 08:01 PM
DomFD3S
Interior / Exterior / Audio
14
Jul 31, 2003 12:34 AM
Mindphrame
May 15, 2003 12:01 PM
Garrett
Mar 27, 2003 09:03 PM
veilside123
Oct 20, 2002 01:37 PM
