bridge porting and a bridge porting machine...anything in common?
Old Jan 26, 2004 | 02:11 PM
just wondering because i know at my dads shop he hav a bridge porter...if so ill do little research and maybe start bridge porting for people for a lot cheaper! well lata
Old Jan 26, 2004 | 02:33 PM
MikeLMR's Avatar
'Last Minute' Rallying
bridgeport is a make of machine tool http://www.bpt.com/
Old Jan 26, 2004 | 03:35 PM
oh thanks for fixing my stupidness...would a persion drill press do the trick? u think? for any kind of porting?
Old Jan 26, 2004 | 03:42 PM
MikeLMR's Avatar
I think bridge ports are usually drilled out and then finished off with a die grinder and a cutting burr. So a drill press sounds like it could be a usefull tool for creating a bridgeport.
Mike
Old Jan 26, 2004 | 05:42 PM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
The big difference between a milling machine a drill press is weight mills are big and heavy to hold stuff firm and resist vibration. You cannot mill anything has any weight to it on a drill press. You could use a mill to do porting but only on the face egdes, not the depth or angle of the port.
Old Jan 26, 2004 | 06:00 PM
well they have a few cnc machines..by the way they make the molds for wilson sporting goods golf *****...so i think after some research i might wright some code for the cnc machine to do it. can someone give me a link to like a "how to bridge port if so that would be great..lata
Old Jan 26, 2004 | 06:17 PM
good luck, seems like an aweful lot of trouble, unless you want to port a lot of housings real fast.
You'll need to write 2 cnc files If I'm not mistaken, b/c of the 2 sides to each rotor.
I really don't know why you wouldn't just get the templates and do them by hand.
Mazdatrix.com has the templates.
Old Jan 26, 2004 | 06:24 PM
1stgen4life's Avatar
Leaking oil like crazy!
Maybe a streetporting code for the machine would be good. Jorx81, I think he said that he wanted to be able to do it for other people for less money, in which case a machine that does it for you would be nice. Good luck.
Old Jan 26, 2004 | 07:56 PM
yeah see i can get the templates and use the machine manuelly to do the first job..and just record the code and easly repeat...but like i said ill have to do some research
Old Jan 27, 2004 | 01:50 AM
Heath's Avatar
MAGNUM SE7EN
If I'm not mistaken my buddy uses a bridgeport end mill to bridgeport housings. His car was a monster so I guess it works
Old Jan 27, 2004 | 08:37 AM
rxtasy3's Avatar
the ports would still need some pollishing by hand.
Old Jan 27, 2004 | 08:45 AM
Heath's Avatar
MAGNUM SE7EN
Oh yes, they certainly need to be shaped and cleaned up before considered complete.
danielbradley2
11
Sep 28, 2015 10:44 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
scissorhands
Sep 16, 2015 01:25 PM
