Things To Do When on the INSIDE
Old Jan 23, 2004 | 06:12 PM
Marcel Burkett's Avatar
Exclamation Things To Do When on the INSIDE
I am going to pull my motor AGAIN soon to replace those faulty O rings ( hope thats all) , I plan to replace the oil pump and also the regulator with a 105-115 psi HP one so I can safety run 10K rpms . Is there anything else I could / should do whilst I'm in there ? , I am also using all original MAZDA soft parts , I use original 3pc seals , rotors are cleaarenced , e shaft polished ,oil jets replaced with webber carby jets and the thermal bypass pellet replaced with the plug.
Old Jan 23, 2004 | 07:59 PM
j200pruf's Avatar
RIP Icemark
What are you doing about rotor bearings and stat. gears?
Old Jan 24, 2004 | 12:39 PM
BDC's Avatar
BDC
BDC Motorsports
.... as well as crank assembly balancing?
B
Old Jan 24, 2004 | 05:10 PM
Correct me if i'm wrong , but aren't the stock FD bearings and stat. gears up to the task?.
Old Jan 24, 2004 | 05:26 PM
chairchild's Avatar
50mpg - oooooh yeah!
10k rpm?
not on stock internals you won't!!!
Old Jan 24, 2004 | 09:41 PM
Already doing 9000 withouy ANY problems.
Old Jan 25, 2004 | 12:16 AM
Wargasm's Avatar
Weird Cat Man
I was reading a technical thing on rotary engines and they had a graph showing the load on the stationary gear teeth as a function of RPM.
Loads doubled when going from 8000 to 9000 RPM. I don't even want to think about what they're like at 10000
Brian
Old Jan 25, 2004 | 04:55 AM
Is that so ? , care to post a link to that info ?.
Old Jan 25, 2004 | 06:42 PM
IGY's Avatar
IGY
I have seen 14998rpm's on Cosmo(same as FD) stationary gears. I have seen 12,000rpm's every weekend for a year on the same motor. I personally was reving to 10,500rpm's on my 1/2 bridge motor. The FD stationary gears can take it. **** I rev 9500+ on my sideported motor. Yes the motor probably won't last 10yrs, but it is fun as hell. I do advise using the same weight rotors. The rotors are stamped with letters on the side similar to the #'s marking side seal grooves. There are A,B,C,D,and E rotors. You can use letters that are next to each other. Use an A with a B or a B with a C and so on.
Old Jan 26, 2004 | 12:20 AM
Wargasm's Avatar
Weird Cat Man
On my FTP....
ftp.zeroglabs.com
username: rx7
password: rx7
file is "REbyKenichiYamamoto.pdf" -- it's in there.
Brian
Old Jan 26, 2004 | 06:34 PM
chairchild's Avatar
and also, at around 88000Rpm, the e-shaft starts to flex.
now imagine all those precision-machined clearances throughout your engine, and now imagine having the main supporting section moving about.
Say bye-bye internals!!
Old Jan 27, 2004 | 04:23 PM
wwilliam54's Avatar
it WILL run
if you dont hold it too high it should do 9500 rpms
but dont hold it
and be warned the apex seals wont last all that long with the chatter from that speed
you could always get ceramic seals :S
Old Jan 29, 2004 | 07:25 AM
The reason for the clearancing of the rotors is to ALLOW the additional movement when doinng higher rpm's.The ideal would be something like the GURU two piece e shaft with center bearing (planned for my semi pp motor) . Everyone says get hardened stationary gears ...., but does everyone know that the FD gears are factory hardened ?.
I think higher oil pressure would be enough , as I said ,I am already doing 9000rpm with my present mods without problems, I will let you'll know whal happens.
Old Jan 29, 2004 | 07:58 AM
IGY's Avatar
IGY
Go for it man. Plenty of oil pressure with stock FD regulator for over 10,000 and yes the FD does have hardened stationary gears. Have fun!
Old Jan 30, 2004 | 05:38 PM
chairchild's Avatar
Here's an idea, instead of paying shitloads of cash for a 2-piece e-shaft and bearing, why not get a 2-piece roller-bearing instead?
Simply fit it around the e-shaft when you're assembling it, and voila!!
A centre bearing
Old Feb 1, 2004 | 05:14 AM
peejay's Avatar
Old [Sch|F]ool
Originally posted by Wargasm
On my FTP....
ftp.zeroglabs.com
username: rx7
password: rx7
Brian
Code:
Connected to ftp.zeroglabs.com.
220 ZGRL FTP
User (ftp.zeroglabs.com:(none)): rx7
331 Password required for rx7.
Password:
230 User rx7 logged in.
ftp> dir
200 Port command successful.
150 Opening data connection for directory list.
drwxr-xr-x   1 ftp      ftp             0 Jul 27  2001 2nd_Gen_RX-7_Manual
drwxr-xr-x   1 ftp      ftp             0 Dec 01  2003 3rd_Gen_RX-7_Manual
drwxr-xr-x   1 ftp      ftp             0 Jan 03 19:18 Car_Movies
drwxr-xr-x   1 ftp      ftp             0 Jan 26 19:03 Car_Movies_2
drwxr-xr-x   1 ftp      ftp             0 Feb 09  2002 RX-7_Parts_Microfiches
drwxr-xr-x   1 ftp      ftp             0 Jan 23 07:27 Upload_Files
-rw-r--r--   1 ftp      ftp        976017 Jun 23  2003 93_vachoses_5speed_ONLY.j
pg
-rw-r--r--   1 ftp      ftp        173024 Feb 16  2001 psremove.zip
-rw-r--r--   1 ftp      ftp       3573055 Jan 22 17:19 REbyKenichiYamamoto.pdf
-rw-r--r--   1 ftp      ftp        282112 Aug 25  2003 renesis_paper.doc
-rw-r--r--   1 ftp      ftp       1217295 Jan 26  2002 Rotary Math.pdf
-rw-r--r--   1 ftp      ftp        101834 Feb 09  2002 wheelcap.zip
226 Transfer ok
ftp: 884 bytes received in 0.17Seconds 5.17Kbytes/sec.
ftp> binary
200 Type set to I.
ftp> get REbyKenichiYamamoto.pdf
150 Opening data connection for REbyKenichiYamamoto.pdf (3573055 bytes).
226 Transfer ok
ftp: 3573055 bytes received in 995.78Seconds 3.59Kbytes/sec.
ftp>
MINE!! ALL MINE!! MUHUHAHAHAHAHahahahaa... (evil laughter continues unabated for minutes)
Man you just made my day!
Old Feb 1, 2004 | 05:18 PM
What da HELL IS DAT ^??? !!!!!
Old Feb 1, 2004 | 07:53 PM
Brian7's Avatar
ftp.zeroglabs.com
username: rx7
password: rx7
Brian
13
Jan 9, 2018 11:19 AM
jsesq
27
Sep 25, 2015 11:10 AM
tiger18
Sep 3, 2015 08:27 PM
