Oil rings
Old Jan 21, 2004 | 12:13 PM
Marcel Burkett's Avatar
Question Oil rings
Which oil control O ring is better between the original MAZDA and th Atkins?. I know that the Mazda is silicone coated with viton and the Atkins is pure viton , but which would really be better for use on my motor?.
Old Jan 21, 2004 | 12:44 PM
kyle@insight's Avatar
Dont like it? I dont care
If I'm not mistaken viton is more heat resistant so my guess would be the atkins is better.
Old Jan 22, 2004 | 07:12 AM
Thanks Kyle for your reply.If anyone else has any more info , can you please post it ?, I need to order soon !
Old Jan 23, 2004 | 02:08 AM
re10's Avatar
10a *****
I understand that the inner O ring is much higher spec than the outer (a friend had a factory set analysed). In fact the outer was nothing special - he found a local after market supply for a much cheaper price, with the same qualities/heat resistance etc etc (just a different colour). Going to be tried in the next race motor re-build...
Old Jan 23, 2004 | 02:14 AM
re10's Avatar
10a *****
Hey Marcel Burkett, a friends RX3 coupe (bright yellow 13B injected PP 13x10 wheels, cage etc) full race car was sold to someone over your way from New Zealand a couple of months ago... do you know anything about it???
Old Jan 23, 2004 | 02:47 AM
PDF's Avatar
PDF
Viton is good stuff. I made my own water seals using viton cord.
13
Jan 9, 2018 11:19 AM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
