How to modifie a Nikki Carb?
Old Jan 13, 2004 | 07:00 PM
jcfrx7's Avatar
Old Jan 13, 2004 | 08:16 PM
1stRX8's Avatar
Tall order. There is a kit that changes it magically into a Dellorto, Weber, or Holley.
1stRX8's Avatar
Mazdatrix. Racing Beat. Should help.
Old Jan 13, 2004 | 08:20 PM
Steve Shulz's Avatar
Ask rx7carl or sterling... they are the ones.
Old Jan 13, 2004 | 08:22 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
yes shoot a pm to rx7carl.... i hear sterling is mean and will call you names. J/k
Old Jan 13, 2004 | 09:30 PM
A few basics:
If you have an 81-85 carb good. Remove all the emissions. Take the intake manifold and carb off of the engine. Get a 79 or 80 manifold, they flow better and don't have the damn shutter valve. Plug the coolant passages leading to the manifold (cools intake charge). Rebuild carb. Get a better fuel pump and a regulator. Take the stock air cleaner housing off. Buy racing beat's power pulse cleaner with a K&N or make your own housing for a K&N using stainless steel sheet metal. Re-jet. (havent done this yet)
A few other things you may wanna do is convert to mechanical secondaries and remove the choke depending on how civilized you want the carb to be.
MAKE SURE that your ignition is timed right and exhaust upgrades are done before you fine tune the carb. You may even want to upgrade to direct fire ignition and do the Yaw power ignition timing mod.
Old Jan 13, 2004 | 09:39 PM
Rx7carl's Avatar
Airflow is my life
Sterling posted detailed instructions on mech secondaries (so did 82 transam) . Also Sterling did a nice write up on increasing the accelerator pump volume and shot. Look in the FAQ page at the top of the forum.
Old Jan 13, 2004 | 09:40 PM
Rx7carl's Avatar
Airflow is my life
You heard that too huh?
Old Jan 13, 2004 | 11:18 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Shut the hell up, moron.
Sterling's Avatar
Old Jan 13, 2004 | 11:45 PM
Rotofire's Avatar
Yea, I'm working on it...
speaking of nikki's how much would as excellent condition (only 79K on it) stock nikki and manifold go for? I need to get a price range. If both are in really good condition, never had problems.
Old Jan 14, 2004 | 07:04 AM
Rx7carl's Avatar
Airflow is my life
I pay $40 max for a used carb. But if its not in need of a rebuild (ie in excellent condition), you might go a little higher. Manifold (79-80) run $35-$50 on ebay.
Old Jan 14, 2004 | 09:19 AM
I would get an 81-85 carb and a 79-80 manifold. The newer carbs are a little better, but the older manifolds flow a little better.
A rebuild isn't really that tough or that expensive but it is very worthwhile.
Old Jan 14, 2004 | 12:38 PM
Rotofire's Avatar
no i've got them for sale i was just getting price checks to see how much to put them up for. but thanks rx7carl
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
