S-afc tuning
Old Jan 7, 2004 | 09:52 PM
kleach18's Avatar
Just Looking Around
S-afc tuning
I already searched and haven't been able to find anything useful.
I need help on uderstanding the s-afc. I know all the setting for the rx7 when I first installed it (flap sensor and such) but I need help understanding what everything means. I don't have a manual and just wondering what it all mean. I have a professional to tune it so I'm not going to tune it myself, I just want to understand it.
Anybody know any site that help me understand it.
I installed it using 1300cc.com so I know about that but it doesn't go into depth about how it works and what it means.
help please!!!!
kleach
Old Jan 7, 2004 | 09:55 PM
SonicRaT's Avatar
Super Raterhater
Go to apexi's website and download the manual. Give me 3 seconds and I'll post a link
Old Jan 7, 2004 | 09:56 PM
SonicRaT's Avatar
Super Raterhater
http://www.apexi-usa.com/productdocu...s_safc_ins.pdf
Old Jan 8, 2004 | 02:05 AM
Scott 89t2's Avatar
SOLD THE RX-7!
the S-afc has both a low and high setting. so you make 2 fuel maps with it.
you set where your low and high start. mine is like 30% low and 80% high or something.
so then you make a low map. the S-afc uses this map when you are under 30% throttle (or what ever it's set at above). you set rpm points and you and can lean or richen it at each rpm point. you can lean it out a bit to save gas.
then you set the high map that is used when the throttle is over 80%. adjust this map using a wide band o2. (tunning) add or remove fuel at each rpm point as needed.
anything between 30 and 80% it calculates an avg between the low and high setting.
Old Jan 8, 2004 | 02:22 AM
I wish I was driving!
I know for a fact that Scott is an excellent SAFC tunner [sic.]
Old Jan 8, 2004 | 02:25 AM
rexman13b's Avatar
good to be back
i wanna know where scott89t2 got that front lip. looks badass.
Old Jan 8, 2004 | 02:29 AM
Its a FEED replica he bought locally. The seller used to sell them on this forum at 300 US or thereabouts, but I believe he has since stopped.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
