junkyard boost
Old Jan 7, 2004 | 07:36 AM
rotarydankus again's Avatar
junkyard boost
heres my currant frankenstien project , he says as the masses tremble at his knees
Old Jan 7, 2004 | 07:44 AM
Rx7carl's Avatar
Airflow is my life
So, is that your plan for mounting? Oh and I'm not trembling, get it running, then we'll see.
Old Jan 7, 2004 | 07:49 AM
jimmdog's Avatar
WTF is it? cant tell from pic
Old Jan 7, 2004 | 08:08 AM
What car did the supercharger come off of?
Old Jan 7, 2004 | 09:23 AM
Directfreak's Avatar
I am a Jeeper Now.
Old Jan 7, 2004 | 10:03 AM
Rx7carl's Avatar
Airflow is my life
I meant location, not the stuff he had it laying on. Damn elitst *****!
Old Jan 7, 2004 | 10:45 AM
RRTEC's Avatar
Rotartist
That's gonna take some fabing.....Will it create as much power as it takes to run it? What did that come off of..an izuzu? How much did you pay?
Old Jan 7, 2004 | 11:20 AM
cafcwest's Avatar
Looks like a Thunderbird SuperCoupe S/C to me. I believe thats an Eaton M-90...not a bad blower at all. I'd just be worried that spinning a rotary to higher rpm with a stock pully would exceed the max rpm for the supercharger.
Old Jan 7, 2004 | 12:09 PM
seanrot's Avatar
Always waiting for parts!
How much did he pay? I think rotarydankus either owns or has a key to the back door of the junkyards in his area.
Old Jan 7, 2004 | 01:12 PM
As a matter of fact I rent my shop from a auto salvage yard, very convenient, !!!!! as for the supy it came of a 90 cougar supercoupe that i bought last year from a police impound auction . it had spun rod bearing , but it had 5 speed and alot of other stuff i sold of, and the whole trunk was full of rebuild parts for cv joints, boota cages ***** races hub nuts you name it it was 550lbs worth of stuff, used the fan on the 7 and plan on using the supercoupe injecters and ecm to run the supercharger moter, cause its configured to crank trigger , should be relatively easy to retro fit for a dankus. carl the manifold will be 6'' fron engine to supy, my fabricater allready has the supy outlet built and the piping to the smaller intake ports tigged on , working on the outer big ports now, injecter bungs are located one in each small port and two each in the larger on, im thinkin the charger being self lubed will help in that it can be mounted in about any position, the way it sits in the pic it clears my header, and a friend works for the company that restores stuff for the kansas cosmosphere, you know they did the apollo 7 after it was recovered , any way he gave me some stuff similiar to the tiles in the space shuttle to insulate the supy from the header, now are you a believer?
Old Jan 7, 2004 | 01:30 PM
TOUGHGUY's Avatar
Got some screws loose!
Keep us updated. I want to see how this thing turns out.
Toughguy
Old Jan 7, 2004 | 01:40 PM
Rotofire's Avatar
Yea, I'm working on it...
lol, sounds sweet, course i'm somwhat of a newb still so i don't quite know all the details but hey you gotta start somewhere keep on truckin
Old Jan 7, 2004 | 07:49 PM
thanks guys been taking my time cause im covered up with other cars to work on, but my friends are very supportive, my fab guy is after me every day to touch it atleast, still have lots f details to work out. one is how to fire the 2 primary injecters at lower engine speeds , and the other 4 inj 2 apiece in the big ports at higher r's and under boost? any cheap ideas , wish i could find some one to reprogram the t bird ecu
Old Jan 7, 2004 | 09:02 PM
QuagmireMan's Avatar
Registered Offender
nice.. that is something i always dreamed of.. taking a sc from a junk yard and putting it on my car.. but the whole bolt thing always threw me for a loop
good Luck
Old Jan 7, 2004 | 09:10 PM
wwilliam54's Avatar
it WILL run
awesome
i was at the junkyard today,
saw a nice tubo diesel,
i wish i could spend the time and money to put a big turbo like the one i saw on
Old Jan 7, 2004 | 09:18 PM
Syscrush's Avatar
Dankus, with all your junkyard and homebuilt stuff, there's only one ECU for you... MegaSquirt! I kid you not - it's an open-source DIY electronic fuel injection system:
Clicky
Costs under $200 to build the ECU, and if you've got a buddy who's handy with the embedded assembly language programming, you can make those staged injectors work any damn way that you choose.
Hope this helps,
Old Jan 7, 2004 | 10:28 PM
actually its been me delagated to ride shot gun and tune, we are working HONDATA rite now on a vortech superchargeds 2k civic, ive definately be interested in the megasquirt, still have the stuff i down loaded years ago, seems idiot proof , wasnt that one guy using them on his ultralite? thats confidence in your cqapibilitys now, and quagmire , maybe ill fab a installation kit and the dream is ypurs, figure it like this , 250 for ebay supy, get the injecters too and the throttle plate, megasquirt 200.00 good t-rex pump 200? misc crap A/n hose etc 200, so approx 850? possibly as much as 250/300 cheaper dependant on your scrounge ability
Old Jan 7, 2004 | 11:15 PM
Chamele03's Avatar
WOAW, if you made a kit i would probably buy it, this sounds sweet
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
