problems....help appreciated
Old Jan 6, 2004 | 06:10 PM
ive recently been confronted with storing my rx7 in the garage for the last week. this sux. there are two problems. first: when i put my key in the ignition and turn it to the "accessory" position the cd player will come on and i have power, however when i turn the key to start the car everything is grounded out and i cant even get the accessories to function anymore. secondly: ole rex wasn't idling right, if i let the car fall below 1700 rpms it or let go of the gas, the car slowly loses rpms and then stalls out. to fix this i took it to a technician and he cleaned out the accelerator pump. this helped somewhat, but the car still wont idle where its suppose to (around 800 rpm) and it still inconsistantly stalls out every once in a while? the mechanics seem to be stumped????? help???? specs are 1983 (12A carb.) any ideas?
Old Jan 6, 2004 | 07:06 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
"Technician", huh?
The accelerator pump has NOTHING to do with the idle circuit!
You probably need a simple tune-up, and seeing as how he felt cleaning the AP out was going to fix it, he probably does'nt know how to tune it.
You can learn yyourself very easily. Just do a search here. Lots of info.
As for the electrical; problem, if your voltmeter is showing better than 12 Volts, then you probably have a bum ignition switch...not uncommon for FBs.
It can either be resoldered, or replaced. Either is a pain in the ***.
You'll know if it is the switch if you remove the plastic cover from the steering column, and try to start the car while pressing on the soldered contact closest to your left knee. Don't worry...no chance of a shock or short, just don't let anything metal touch them.
Old Jan 6, 2004 | 07:07 PM
Sterling's Avatar
-BTW, welcome!
Old Jan 6, 2004 | 07:21 PM
no chance it could be the wires running from the battery or ignition?
Old Jan 6, 2004 | 07:22 PM
and thanx for answering as ive found its hard to get a response around here
Old Jan 6, 2004 | 07:26 PM
another vital detail may be that i can start the car by getting jumped by another vehicle but it doesn't even seem to have to charge, i just hook up the jump and it starts right away
Old Jan 6, 2004 | 08:29 PM
Steve Shulz's Avatar
Pull of your battery terminals, clean them up re-install. should be fine after that. Welcome..
Old Jan 6, 2004 | 08:48 PM
Sterling's Avatar
Ahhh...
Could be as Steve says, and it can also be a starter solenoid terminal corrosion.
Old Jan 6, 2004 | 08:54 PM
thanx a bunch for the help guys. im out
Old Jan 6, 2004 | 09:27 PM
Post your results when you get the chance. Good luck.
Old Jan 6, 2004 | 09:38 PM
Rx7carl's Avatar
Airflow is my life
Classic case of a probable bad ground for the battery cable, or poor connection on one of them (maybe the starter as was suggested). Id investigate that first. Yes Ive seen switches go bad, but your telling us that an additional battey jumped to it makes it start leans towards a bad connection.
For the crappy idle. You prolly have a vacuum leak. Mybe something as simple as a hose come off. Maybe your "technician" bumped one, or forgot to reconnect one.
Old Jan 6, 2004 | 11:12 PM
Rotofire's Avatar
Yea, I'm working on it...
maybe there is a carny midget hidding in your dash, they like to do that ya know
Sh00bs
Oct 1, 2015 11:57 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
93FD510
Oct 1, 2015 02:00 PM
