"Alternator Belt is a B**** to put on damnit"
Old Jan 5, 2004 | 12:39 PM
theone81's Avatar
Angry "Alternator Belt is a B**** to put on damnit"
Its been fustrating puting on this last Drive belt.. Im using an Aftermarket belt.. but due to the fustration of Losening the tention Bolts to "LOOSEN THE ALTERNATOR THAT WON'T BUDGE" TO LOSEN ANYWAYS" Im just gonna buy an OEM BELT I hope it fits better!!!!
Old Jan 5, 2004 | 12:41 PM
silverrotor's Avatar
Did you try rotating the Main Crank awhile slipping the Belt on? Do you even have the correct sized belt?
Old Jan 5, 2004 | 01:00 PM
Kenteth's Avatar
Like Ghandi with a gun
is that belt tiny as hell, or are you not able to move tha alt at all due to stuck-fast alt mount bolts?
Old Jan 5, 2004 | 01:02 PM
SureShot's Avatar
Seduced by the DARK SIDE
Did you loosen the 14mm alternator pivot bolt?
It makes me envy the guys with an E-fan & no PS or AC or air pump.
Old Jan 5, 2004 | 01:04 PM
theone81's Avatar
I just got the OEM Belt "Right Now" Its in fact "A Shy bigger than the Aftermarket one" I hope this works when i get home..
Old Jan 5, 2004 | 01:05 PM
zinx's Avatar
_________________________
You haven't loosened something. All the belts are very easy to replace.
Old Jan 5, 2004 | 01:08 PM
zinx's Avatar
Atleast they are on my S4 N/A. I just realized that you have a S5 T2, so i prolly don't know what i'm talking about.
Old Jan 5, 2004 | 01:10 PM
theone81's Avatar
I fOllowed the Instructions from "CHILTON" Ive losend the Bolts already but moving it seemed some hard work!
Old Jan 5, 2004 | 01:27 PM
jacobcartmill's Avatar
just dont care.
the belts are the same
Old Jan 5, 2004 | 01:28 PM
just dont care.
dude i just put my two alternator belts on last night (dual alt pulley)
just loosen that pivot bolt and use a convincer bar to get the alt to move down all the way.
Old Jan 5, 2004 | 01:32 PM
theone81's Avatar
Where do i place the bar to pull it up or down... what is that?
Old Jan 5, 2004 | 01:40 PM
just dont care.
just loosen that bolt, put a bigass block of wood ontop of the alternator, and hit the block with a sledgehammer.
Old Jan 5, 2004 | 02:14 PM
theone81's Avatar
It will probabaly be a Bitch to Put it back up with a new Alternator belt... "Aftermarket that is"
LunchboxCritter
15
Jan 3, 2016 04:11 PM
rotor_veux
Aug 31, 2015 07:49 PM
dillrx7
13
Aug 31, 2015 08:39 AM
sYnth.
Aug 19, 2015 06:27 PM
