temp sender on 85 12a
Old Jan 3, 2004 | 12:28 PM
Angry temp sender on 85 12a
I need a little help with the location of the temp sender. I know its located on the block somewhere near the oil filler, but I don't see it.
Old Jan 3, 2004 | 01:27 PM
kettlman's Avatar
THE ONE. THE ONLY!
it should be on the rear casing, below the oil filter, above the heater hose to the left . here i'll post a pic. there should be a yellow wire hooked to it.
pic
Old Jan 3, 2004 | 01:29 PM
wwilliam54's Avatar
it WILL run
up an the the rear of the oil sender
its just a prong
Old Jan 3, 2004 | 02:23 PM
picsss
I took a few pics, plus one of the ride since I have'nt yet
Old Jan 3, 2004 | 02:29 PM
Rx7carl's Avatar
Airflow is my life
SO can you see from Kettlmans pic where it goes?
Old Jan 3, 2004 | 02:42 PM
It would'nt be in a different location because its a california car could it? I'm looking at the area in the pic, I'm not seeing it
Old Jan 3, 2004 | 02:46 PM
mar3's Avatar
Administrator
What does the sensor do that screws into the back of the water pump housing at the front of the engine?
Old Jan 3, 2004 | 02:50 PM
inittab's Avatar
I read your email
That controls the choke. My question is what does the sensor do at the bottom of the radiator?
Old Jan 3, 2004 | 02:55 PM
Rx7carl's Avatar
Airflow is my life
Nope, same spot dude. Its really small though and usually covered in dirt.
And for the hijackers. The one on the rad is for the emissions control computer.
Old Jan 3, 2004 | 03:02 PM
inittab's Avatar
I read your email
haha
BTW, I just added this thread to the FAQ. Now everyone will know all about the all-important temperature sensors.
Old Jan 3, 2004 | 03:56 PM
I did see a small opening behind the oil sender but the part I have didn't fit. Could it be missing? wouldn't water shoot out if so?
Old Jan 3, 2004 | 04:04 PM
inittab's Avatar
I read your email
Yes, that looks like the part BUT..... Quoted from this Mazdatrix page: Sensors, Senders, and Miscellaneous Electrical
"Note: A few years ago MAZDA changed the thread on the water temp sender in the rear side housing from the straight thread that they had used forever, to a metric pipe thread. All NEW rear housings have the new thread. It is essentially impossible to tell which you have with out looking at it. Most cars still use the straight thread. However, if the engine has been replaced with a FACTORY rebuilt, there is a small chance you have the pipe thread. The new sender will not read correctly in pre-80 cars"
Old Jan 3, 2004 | 04:11 PM
I could have the wrong one, since there were but could it be missing from the car? The hole that is there is a little smaller than the part I have, so I'm not sure about the threads in the housing.
Old Jan 6, 2004 | 09:35 AM
Well, the temp sender is broke off in the block, I tested the loose yellow wire with a test light and the gauge went up some, so it works. Anyway, anyone have any suggestions for technique, tools, etc. to get this thing out?
Old Jan 6, 2004 | 10:07 AM
Rx7carl's Avatar
Airflow is my life
Drill and an easy out.
Old Jan 6, 2004 | 10:18 AM
Ludicrous's Avatar
Drive it like u stole it
Mine broke, too. It's a pain in the *** to get it out, but like Carl said, an easy out will do it, but you're not gonna have a lot of room to work with.
Old Jan 6, 2004 | 10:37 AM
Thanks for the help, I'm gonna get it done this week
Old Jan 6, 2004 | 11:09 AM
kettlman's Avatar
THE ONE. THE ONLY!
i'm glad you got it figures out.
Old Apr 2, 2004 | 05:30 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
I thought the choke ran off of the main water temp sensor in the driver side's of the engine. Mine is not connected right now and I though that's why the choke wasn't working
Old Apr 2, 2004 | 05:53 PM
hiboost7's Avatar
umm i think he has the sensor behind the water pump housing.... thats called the temp. sensor as well. thats what its called on the advanced auto parts computer. is it about a half inch thick and have two wires sticking out the back?
Old Apr 2, 2004 | 06:19 PM
FB II's Avatar
when in doubt, spray the area with carb cleaner. might help.
Old Apr 3, 2004 | 07:31 PM
cdrad51's Avatar
Ok. Now here's an important question. I don't have a temp sensor in the block right now. Could I wire the temp gauge to the sensor in the back of the water pump housing? i.e. do they have the same resistance for the same temperature?
Old Dec 5, 2007 | 03:26 AM
80DrIfTeR's Avatar
ASE ****** Mechanic
i have the same concern... i use the opening in the back of the water pump housing to run my Water Temp Guage... its an aftermarket guage and i just screwed the fitting into the hole.... the person who had this car before me had the same thing setup, but the guage crapped out.... how is this gonna affect my dellorto carb and choke? if i dont have anything plugged into it from the water pump housing???
Old Dec 5, 2007 | 09:27 AM
85 FB's Avatar
7-less
My recommendation is to put the correct plug into the water housing and run a new adapter for your temp sender where the stock one is located.
I'm not sure what the thread size is, but check this link just in case.
http://www.pegasusautoracing.com/Pro...asp?RecId=3142
Old Dec 5, 2007 | 12:24 PM
85 FB's Avatar
7-less
Upon doing some searching, might not have to worry about the location of the sender. Try this link, see if there are some answers in there that should help you.
https://www.rx7club.com/1st-generation-specific-1979-1985-18/aftermarket-water-temp-gauge-install-adapter-fitting-311349/
