Boost Lost By Changing Pills
Old Dec 29, 2003 | 12:47 AM
fd3s_rx7's Avatar
HELP!!!
I've decided to change my actuator pills (wastegate
controller) and actuator (turbo precontrol) plus the
actuator (charge control) to high silicon hoses and
notice a pattern of 6-5-6lbs. Now I'm loss. I've checked
the connection over and everything looked fine. Was I
not suppose to change the pills to silicon hoses or what?
Old Dec 29, 2003 | 12:50 AM
spoolin93r1's Avatar
did you put the plastic pills in the new lines? if not, it will cause a drop in the signal to the actuators, meaning less boost
Old Dec 29, 2003 | 12:56 AM
fd3s_rx7's Avatar
the picture
Old Dec 29, 2003 | 12:58 AM
Snook's Avatar
Tony Stewart Killer.
they should be metal pills and yeah what he said
replace the hoses but feel the lines there are 2 that have pills wastegate and precontrol...put those back in
Old Dec 29, 2003 | 01:02 AM
fd3s_rx7's Avatar
what do you mean plastic pills.?
sorry but all I did was change them stock hoses to silicon hoses. I do notice some little oil on the stock hoses before I change it to the silicon hoses.
Old Dec 29, 2003 | 01:09 AM
EviLPeNeviL's Avatar
Can't live without boost.
This happened to me once right before a dyno pull. I had changed one of the hoses that contained the pill and I had only pulled 7psi max. Scared the hell outta me, went back home and good thing I save everything that I change and the pill was still in the old hose. Changed it and it pulled like a dream after that.
-Dan
Old Dec 29, 2003 | 01:18 AM
fd3s_rx7's Avatar
WOW THANKS ALOT!!
I FOUND THE PILLS IN THE HOSES!
Whew I was scare like hell, but the problem is do I just cut these open and put it in the silicon hoses and replace it.?
The other thing is how do I know which pill goes to which now?
Thanks alot guys!
Old Dec 29, 2003 | 01:29 AM
fd3s_rx7's Avatar
so if I am loosing a pill for the actuator (turbo precontrol)
will that result in a pattern like this 13-10-7
Old Dec 29, 2003 | 01:59 AM
Houdini's Avatar
last I remember, pill with the larger hole goes in the shorter hose.
Old Dec 29, 2003 | 08:19 AM
Kas's Avatar
Kas
the pill with the larger hole controls wastegate small1 prespool secondary I think. I relpaced them with home depot valves this weekend.
Old Dec 29, 2003 | 11:54 AM
fd3s_rx7's Avatar
does it matters what sides you put it into?
and does it matters from the length of the pills to the actuator?
Old Dec 29, 2003 | 12:17 PM
Cihuuy's Avatar
hmmm... this is what im looking for...
Can you guys post the pills pix that your talking about... all i see is an x in the box.
im having boost 7-7-7 after i change my vac.hoses!!
I still have all the old vac.hoses but its in a box mixed with other junks... so i dont know which was the old wastegate/precontrol hoses...
Old Dec 29, 2003 | 12:48 PM
fd3s_rx7's Avatar
There should only be two vac hoses.
The waste gate controller and the turbo precontrol actuators vac hoses.
You will have to look for those hoses because those gaddamn pills does make that of a difference.!
Look inside every of your vac hoses and see if you can
see a small metal pill in it. The pill have to be in one of
those hoses.!
The bigger pill goes to the waste gate controller, and
the smaller pill goes to the precontrol hose.
I just finished mine and I think I have awaken the long
sleeping beast.
When I get a picture I will post it for you guys.
Old Dec 29, 2003 | 12:58 PM
Cihuuy's Avatar
fd3s_rx7:
damn... its almost 3 am over here!!
ill go and check in the morning, hopefully i didnt throw away those vac.hoses...
The beast is still sleeping here
Old Dec 29, 2003 | 01:00 PM
fd3s_rx7's Avatar
Originally posted by fd3s_rx7
the picture
C:\Documents and Settings\bee\My Documents\My Pictures\MIxEd FiLeS
Old Dec 29, 2003 | 01:09 PM
fd3s_rx7's Avatar
fd3s_rx7:
For some reason I can't get the picture to be posted but anyways, yeah you should find those two hoses that contain the two small metal pills inside them.
Old Dec 29, 2003 | 01:35 PM
Cihuuy's Avatar
hahaha...
it is soooo bloody tempting that i had to find the two hoses... after burning and cutting some of the hard vac.hoses i finally found them... I FEEL SOOOO GOOD!!! hehehe
can rest/sleep in peace now... cheers mate
DerpyToast
14
Nov 23, 2024 05:19 PM
SCinfidel
Sep 8, 2015 05:36 PM
immanuel__7
Megasquirt Forum
14
Sep 7, 2015 07:25 PM
AXA
Sep 5, 2015 10:06 AM
