clutch feel
Old Dec 17, 2003 | 07:15 PM
Chamele03's Avatar
clutch feel
Ok im worried, cause when i had the slave cylinder off my car I accidentally tapped the clutch pedal and have alway been told this is a major no,no. but i got it on, and bleed'ed'ed(?) and now i can shift( finally drove it for the first time since i bought it in aug.) but the pedal is really soft, the only thing i have to compare to is my honda, and its so tight, you only have to push it half way down. and my friends Mazda mx-3 has a soft clutch, im hoppin its supposed to be soft, but u guys drive em, how does the clutch feel?
Old Dec 17, 2003 | 11:19 PM
brianw's Avatar
Just got done going thruogh that. I ended up with a new MC,SC,and soft lin to the SC. feels nice and hard now.
Old Dec 17, 2003 | 11:41 PM
FD Racer's Avatar
sold the FD...kept the FB
your're probably okay. Was the SC leaking at all? I think it's only bad when you push the pedal all the way down with the SC not pushing on anything.... it can literally pop the piston off if there is no resistance. If you only tapped it, and its not leaking, you should be fine. Soft stock clutches are normal.
Old Dec 17, 2003 | 11:42 PM
Chamele03's Avatar
so are you saying it should be stiff?, i need input im paranoid about this but i wanna drive it SO bad, it made me feel almost high driving it tonight( but htat could be the exauhst leak?)
edit: cool makin me feel alot better FD, cause i just barely tapped it then freaked, it wasnt leaking from anywhere.
Old Dec 18, 2003 | 09:39 AM
erick1120's Avatar
I have a new pressure plate, clutch disk (both stock) and have bleed the system and mine still feels soft compared to other clutches. I haven't had any problem with it and it has been that way for about 6 months now. I wouldn't worry if I were you.
Old Dec 18, 2003 | 12:42 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
Between myself, erick1120, and ROTORCOASTER, all three of our clutches feel different. Yet there are no known problems with any of them. I will say this though, mine felt the most "normal" to all of us, just before my slave went out. Now that it has been rebuilt again, this time correctly, it feels much harder than it did.
Bottom line, the feel isn't really as important as how it works. If you aren't having any problems with it engaging/disengaging, don't sweat it too much.
Happy Rotorin'
Brian
Old Dec 18, 2003 | 04:37 PM
oni-dori's Avatar
Back from the dead
mine is pretty soft too. at least compared to my honda accord. ive driven proteges and they are about as soft as my 7. nothing's leaking, so im just guessing everythings normal.
Old Dec 18, 2003 | 11:01 PM
Mines firm. I replaced the MC and SC recently.
Old Dec 18, 2003 | 11:21 PM
oni-dori's Avatar
Back from the dead
but i dont see any leaks. and there's no fluid loss either. well, in any case, i dont want to change the mc before i switch to rear discs. that way i take care of it all at one time.
Old Dec 19, 2003 | 12:02 PM
MarkPerez's Avatar
Tennis, anyone
1st gen rx7's clutch hydro's make the pedal feel like mush. i hate it !! i've bored, honed,enlarged,extended,shortened,replaced,rebuilt ,
different size lines both hard and soft, stainless steel braided hoses, the whole clutch (hi-preformance)
the whole thing works good, it just feels like mush
by design
Old Dec 21, 2003 | 03:27 PM
Through all your boring and honing and whatever. What did you find that improved the pedal feel the most. Wouldn't it feel better if you bored it. I would like to have a real short clutch throw.
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 9, 2015 08:06 PM
REX7&Z32TT
Sep 9, 2015 05:16 AM
Enzo1944
Sep 6, 2015 08:57 AM
