hows this for a spool up device
Old Dec 17, 2003 | 05:50 AM
LT1-7's Avatar
John
I was thinking about how to make a huge turbo spool faster without having a strait through exhaust that can me heard from miles away. Well I thought of getting a Tail wastegate with a 2lb spring. Route it into the dp right after the turbo. Connect the boost reference line to the IC piping right after the turbo. This should open up the wastegate right when you go WOT and would pretty much flow better than exhaust you could get. It would be loud as hell but if you have an open wastegate anyways it shouldn't matter and would only open up at WOT.
BMW also has a device sort of like this but works off vacuum. The valve is closed when there is vacuum and then opens up when there isn't. This device is made for the 3 series 2001 and up I believe. It's used to do from single to dual exhaust. The only reason why I don;t think this would work is bacause BMW uses this at the very end of the exhaust right at the exhaust tip so heat might be a concern
Would this work?
Old Dec 17, 2003 | 09:30 AM
NewbernD's Avatar
Tequila? ..it's like beer
Something like this would be easier.
http://www.autospeed.com/cms/A_0883/article.html
Good bit cheaper than a wastegate too.
Old Dec 17, 2003 | 01:16 PM
$150FC's Avatar
Currently Winning
Two open-air wastegates aren't going to be heard from miles away?
Old Dec 17, 2003 | 04:15 PM
where can one buy that kit?
Old Dec 18, 2003 | 03:01 AM
LT1-7's Avatar
John
Only at WOT. This way you can have a quite exhaust, even a stock exhaust but still get good spool up
The link posted by newbern is a much better idea and is kind of like BMW's. Just need to find out where to get one now
Old Dec 18, 2003 | 06:10 AM
twokrx7's Avatar
Need more sleep
There are better exhaust cut-out valves on the market that would work way better than a wastegate ... should be able to get them in full 3" diameter. Recall seeing one on Trucks, ya might try a search on their website.
Old Dec 18, 2003 | 06:53 AM
NewbernD's Avatar
I remember doing some research on Google and found it.. It was somewhere in Austrailia and was going for around $300.
Old Dec 18, 2003 | 07:47 AM
LT1-7's Avatar
John
I think the kit you are talking about is an electronic valve that opens and closes much like a TB. I have heard numerous stories about those not sealing up after a few weeks. It will take some abuse for a wastegate not to seal. BTW, a Tial 38mm wg is only $200
Old Dec 18, 2003 | 12:25 PM
I like the idea of a wg ona downpipe. My only question is, when you work on your exaust, downpipe straight pipe, etc. Get all that stuff, then you have to tune you car for it. Would this require tunning?
Old Dec 18, 2003 | 06:17 PM
Trav's Avatar
Anyone else find this picture "strangely familiar" ??
Old Dec 18, 2003 | 08:39 PM
teamstealth's Avatar
Ozone Depleter
im thinking double throttle body
this is along the same lines...but controlled electrically. No silicone lines to melt on your downpipe
http://www.pfyc.com/store/merchant.m...ory_Code=GAEXH
-Zach
Old Dec 18, 2003 | 08:40 PM
Heath's Avatar
MAGNUM SE7EN
Are you referring to the beloved rotor shape of the flange?
Ian_D
Oct 14, 2015 12:31 PM
Snook
14
Oct 1, 2015 10:56 AM
rotor_veux
Sep 3, 2015 07:10 PM
