my new catch can
Old Dec 17, 2003 | 01:24 AM
rockshox's Avatar
my new catch can
Well I couldnt find any catch cans I liked, mostly lack of any baffles or filtering, no drain valve (you are supposed to remove the level indicator to drain), and the rediculous cost. So I decided to make my own. Attached is a shot before painting. I am thinking of masking 2 stripes down the sides and painting the rest or maybe just leave it clear.
Internally it has a baffle to prevent oil from climbing the walls under high lateral Gs, and a bronze wool filter on the intake line to help condense out any moisture or oil. At the bottom is a drain valve. It is 2.5" diameter and 6.5" long which means it holds a little less than a pint. Construction is of 100% polycarbonate (lexan) for strength and heat resistance. Oh yeah cost was about $15 in parts.
Old Dec 18, 2003 | 11:04 PM
Ranzo's Avatar
Good job!! I like it when people get resourceful and manufacture their own stuff.....
Details on how you did it??
Old Dec 23, 2003 | 12:35 PM
Silkworm's Avatar
Has been.. hangin' around
Cool stuff! Looks good.
PaulC
Old Dec 23, 2003 | 06:16 PM
Kill No Cone's Avatar
Sweet, nicely done!
Old Dec 30, 2003 | 03:36 PM
twister's Avatar
Excellent, I like it!
Old Jan 2, 2004 | 03:07 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
where did you get the parts for it?
Old Jan 3, 2004 | 10:20 PM
Mark'sMazda's Avatar
stop stealing my avatar
that looks cool.
I just bought a clear fuel filter for mine, it works great so far. To run it on an FC, I blocked the vent on the block, and ran a line from the nipple on the oil filler neck to the bottem of the fuel filter. So any overflow, will just drain back into teh crank case. I have no digi cam or I would throw up a pic.
Old Jan 4, 2004 | 12:01 AM
rockshox's Avatar
thanks for the comments guys.
i got all the parts except the end discs from mcmaster. i had the discs made at a local place called tap plastics.
construction is all polycarbonate of a 2.5" od 1/8 wall tube and 1/4" ends with a 1/8" thick disc for the baffle. the internal part to hold the brass wool is 5/8" od 1/16 wall polycarbonate with 2 brass brads through the side. the nipples are 1/8 npt to 1/4 hose barb made of PVDF.
its really simple just drill and tap the holes for the nipples and drain, and glue everything together with solvent glue.
NotMrButts
Feb 10, 2018 06:36 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Aramir
Oct 18, 2015 02:39 AM
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
sherff
Sep 12, 2015 12:22 PM
