Spark
Old Dec 13, 2003 | 05:12 PM
exodus82's Avatar
Spark
Should all of the spark plugs spark during ignition?? Only my trailing plugs are firing. I've checked my ignitors and they are good. When should the trailing and leading plugs be firing and what could make the leading plugs not fire. I have new plugs, wires, and coils.
Old Dec 13, 2003 | 10:03 PM
erick1120's Avatar
The leading will fire first then the trailing. Have you check the cap are rotor. It either has to be that or for some reason the leading coil is not getting power. Try switching all the wires that go to the coils (leading and trailing), cap, and plugs and see if the leading fire and the trailing stop. If they do then you know there is a problem with power to the coil.
Old Dec 13, 2003 | 11:21 PM
exodus82's Avatar
ill try that, im having trouble finding a cap and rotor anywhere. Noone caries it.
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
