Can anyone help me with this TO4?
Old Dec 5, 2003 | 03:32 PM
Cory Simpson's Avatar
I wanta be with the BUC!
Question Can anyone help me with this TO4?
OK, I bought a TO4 on ebay knowing nothing about, his description gave no mesurements or anything.
Any it got here, and the compressor houseing says .60 AR, and it has a 4" TID, and a 2" outlet.
The exhaust side is WAYYYYY bigger than what I wanted, but it says 1.15 AR on it. And it is tang divided. And the DP is a V-band and the turbine wheel measures about 2.25-2.5 in diamiter, or the part you can see.
Does anyone know the compressor trim? Is it a 60-1?
Also it is an airesearch turbo.
And another thing that is wrong with it, is that it doesn't spin freely, it is acctualy pretty hard to turn, I put oil, in it hopeing it just needed lubed, but that didn't help. It has nearly no shaft play, it acctualy feels brand new. But I put a shop vac on the DP part, and it barly blew any air from the compressor outlet. Does anyone have any guess to why that is?
Old Dec 5, 2003 | 05:54 PM
Fox4Life's Avatar
I dont think its a 60-1 compressor because im pretty sure that all 60-1's have a .70 front cover.
Maybe its to4e? ive seen a few of them with 4 inch inlets. Never seen a to4b with a 4 inch inlet.
Old Dec 5, 2003 | 07:32 PM
Yeah, a correct on my measurement.
The TID is a 3", which probably just makes it a TO4B I guess.
Jesus, that 1.15 AR exhaust is going to suck on my 7MGTE.
lag lag lag lag, boossttttttttt..........
Old Dec 6, 2003 | 12:02 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I have that turbo also.
Old Dec 6, 2003 | 12:07 PM
setzep's Avatar
You're probably going to want to get a smaller turbine housing for the 7mgte. Probably closer to a .84 divided with a good manifold.
Old Dec 6, 2003 | 12:46 PM
Yeah, most people suggest nothing bigger than a .70 for street driveing.
But my brother mapped the turbo with the bore, stroke, and # of cylinders of the 7M, and it said that it would be spooled by 3500 RPM's, and would still be climbing at 7500 RPM's. And that it was good for 450+HP.
Also I believe after everything I have read and been told that it is a TO4E with a P trim exhaust wheel and a 60-1 compressor houseing trim.
Good deal for $125 bucks
Old Dec 7, 2003 | 10:28 AM
setzep's Avatar
125, not a bad deal. Hell put it on and if you don't like it sell the housing and buy a smaller one.
Old Dec 7, 2003 | 03:43 PM
PPC-Racing's Avatar
it sounds like the to4a-25, it's an agricultural turbo, with a 1.15 turbine side and a .60 compressor side, the scroll it's self is not that much bigger then a t03 super 60 compressor. Switzer made a copy of the turbo as well it was so popular with the agri industry. you can replace the 1.15 with an .83 or .85 can't remember which..
Old Dec 8, 2003 | 01:34 AM
Benjamin's Avatar
the 1.15 is bigger, but I've got a .96, and it's at 15lb by 3800rpm. Granted, it's the HiFi, but I wouldn't worry about the lag,lag,lag comments--it's not really that bad.
-BN
Old Dec 8, 2003 | 02:59 PM
Do you have a supra?
If it's on an RX-7, that is probably why, I believe the supra puts out less exhaust gas, but I could be wrong.
Old Dec 8, 2003 | 07:24 PM
setzep's Avatar
Yeah, you probably should have asked this question on a supra forum
Old Dec 10, 2003 | 06:02 PM
http://www.msnusers.com/fuelcutswitc...to&PhotoID=186
Humm well I thought I would just post a picture of the turbo, just because I got my 50MM HKS wastegate. And I was purely amazed at how big the wastegate is. I'm gonna have a dump tube as big as some people's exhaust
dillrx7
Sep 7, 2015 09:38 AM
82streetracer
Aug 23, 2015 09:28 AM
penko
Rotary Car Performance
14
Feb 20, 2002 02:45 PM
IAN
Feb 5, 2002 09:03 PM
FourtyOunce
Nov 3, 2001 06:28 AM
