secondary port
Old Dec 5, 2003 | 12:07 AM
chuck8313BTSDS's Avatar
secondary port
suggestions on making these ports better. Looking for fairly good idle with good bottom end power. T66 turbo .96 a/r p-trim, 20-23psi boost.
Ports are not 100% done, need sanding.
chuck
Old Dec 5, 2003 | 12:45 AM
Thought I would add a pic of the primary port.
chuck
Old Dec 5, 2003 | 02:57 PM
BDC's Avatar
BDC
BDC Motorsports
Primaries look fantastic on the bottom from what I can tell.
Secondary port outlet needs to exit more of an angle upwards towards the compression stroke instead of 90 degrees outward from the housing. Pay close attention to matching the cast iron up w/ the nitrided plating as well as tapering and edging the short radius of the port outlet.
Looks good so far.
B
Old Dec 5, 2003 | 06:32 PM
BDC
Are you saying, make the top of the secondary port angle the same as my primary port angle? Most times I go up 8-9mm on the secondary ports with around 30-40deg angle from the bottom of the port to the end plate face.
have another question: What gives more low end power, porting out or porting up?
Thanks for your suggestion.
chuck
Old Dec 5, 2003 | 06:46 PM
chairchild's Avatar
50mpg - oooooh yeah!
less porting gives more low-end
Old Jan 3, 2004 | 07:56 PM
sevenin7's Avatar
chuck83 these porting are for FD engine ?
Old Jan 3, 2004 | 10:10 PM
sevenin7
S5 motor.
chuck
Old Jan 4, 2004 | 07:23 AM
sevenin7's Avatar
chuck83 sorry but what kind of motor is S5 ?
Old Jan 4, 2004 | 05:52 PM
TurboII motors.
chuck
Old Jan 5, 2004 | 03:27 PM
sevenin7's Avatar
o.k thanks
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
