Need input for reaching 400whp with my FC?
Old Dec 1, 2003 | 01:45 PM
3RotorRocket's Avatar
Im starting to brew up a plan for my FC to reach 400whp or more and I need a little help as for the turbo selection and planning.Im new to turbocharged cars and their management systems.What turbo should I aim at getting and what's best for my goal?What about management?Here's a thread from the previous owner of my car so you can see what model it is and the little mods.
https://www.rx7club.com/showthread.p...hreadid=176211
Old Dec 1, 2003 | 04:29 PM
you need some injector. a set of 1600cc with rail, fuel pump, haltch or microtech. get t04s or t66 . ported motor will do it
Old Dec 1, 2003 | 04:45 PM
sillbeer's Avatar
How about the TD06 25G? Is that good for a reliable 400rwhp? How responsive is it with a good street port?
-Destin
Old Dec 1, 2003 | 06:31 PM
Fox4Life's Avatar
Tdo6 is probably going to be a little small.
As for 3rotorrocket, Im almost done buying everything i need to make 400 Hp. I started off with about that same amount of mods you did about 2 months ago when i put my car up. and I have been ordering new parts ever since. One thing i can tell you is that it is expensive. You take into account all the big stuff you need, Turbo, FMIC, standalone, Fuel stuff, And after that youve just got started. Its all the little things that end up killing you in the end.
Old Dec 1, 2003 | 06:51 PM
Well thanks for the warning bro.A T66 can reach 400whp with a ported motor which mine may be? Does Turbonetics have a good T66 turbo to offer the FC?
Old Dec 1, 2003 | 09:48 PM
Fox4Life's Avatar
Sorry, my last post was kinda half assed because i had to leave.
Anyways, to elaborate a little more. All im saying is that its things like, the boost controller, Wastegate, FPR, manifold, fuel rails, all the lines and fittings, DP Ect ect...The list goes on and on. those are the things that really eat you up, because you dont think of em at first.
And yea, a T66 on a ported motor will hit 400 HP at a reasonable boost level pretty easily.
Fox4Life's Avatar
Double post.
Old Dec 1, 2003 | 11:26 PM
$150FC's Avatar
Currently Winning
i think there are less laggy ways to make 400rwhp than a t66
Old Dec 2, 2003 | 05:46 AM
Please fill me in,as of now im planning on a T66.I heard T66's on rotary engines are a great set up.
Old Dec 2, 2003 | 07:54 AM
Turblown's Avatar
Turn up the boost
td07/25G, 60-1, T04S, To4e 60 trim. ect.
Rotary Performance Parts
Old Dec 2, 2003 | 08:12 AM
eViLRotor's Avatar
Brother of the Rotary
A T-66 would be a nice turbo to have, but if you want max 400 whp, then go with a T60-1 (T04S). 15-18 psi should get you there, depending on porting, tuning etc.
I'd take the T04B60-1 over the T04E "60". Larger compressor and higher flow.
Old Dec 2, 2003 | 02:04 PM
The T04s are T60s?I think im still gonna go with the T66 but im going to have a 50 shot of nitrous to handle the lagg that the T66 would give.What's the difference between the T04B and the T04E?Like I said im new to turbos.
Old Dec 2, 2003 | 03:37 PM
eViLRotor's Avatar
Yes, the HKS T04S is a 60-1 compressor with whatever housing A/R's that they use.
The difference between the (T04B)60-1 and the T04E "60": the 60-1 is a larger compressor wheel, the comp housing has a larger inlet, and overall it flows more.
Although the T04E "60" is a newer and more efficient design, the T04B 60-1 will make more power, on our cars anyway.
Old Dec 2, 2003 | 03:45 PM
sillbeer's Avatar
I'm not talking about the TD06 20G turbine which is rated at 400. The TD06 25G is very similar to the TD07. The TD06 25G is rated at something like 650. Buddy of mine is making close to 600rwhp on his from an sr20det.
-Destin
Old Dec 2, 2003 | 03:54 PM
Toss up some pics of the turbos were talking about here or a site with good info on them,these ones specificlly were talking about.The T66,T04B,T04E,TD06 20G and any other good turbos for this goal.Thanks peps!
Old Dec 3, 2003 | 01:30 PM
sillbeer's Avatar
I found alot of td06 25g rx7 Japanese sites through google.com but none in the states. I did find out the compressor wheel is a 60 Trim and the exhaust comes in 8,10, or 16cm.
-Destin
Old Dec 4, 2003 | 02:38 AM
BDC's Avatar
BDC
BDC Motorsports
PM me if you'd like for me to port, modify, and build a motor for you to do this. It's right up my alley.
B
Old Dec 4, 2003 | 06:34 PM
B
Read this thread I may have a port allready....
https://www.rx7club.com/showthread.p...threadid=176211
If not when it comes time for a rebuild and it doesn't have a port i'll send it to you anyway.If it is ported it would be a street port,I would want a bridge port then.
Old Dec 4, 2003 | 11:56 PM
BDC's Avatar
BDC
BDC Motorsports
I think you'd like my half-BP turbo motor job. As long as you have a standalone EFI system to set it up, I don't have a problem doing it for you. Let me know on it; I'd like to get the job. I can make several modifications to the engine to help ensure long-term reliability and power output.
B
Old Dec 5, 2003 | 02:13 AM
Ranzo's Avatar
[quote]I'm not talking about the TD06 20G turbine which is rated at 400. The TD06 25G is very similar to the TD07. The TD06 25G is rated at something like 650. Buddy of mine is making close to 600rwhp on his from an sr20det.
-Destin[/quore]
The TDo6 20G will not easily make 400hp. If you boosted 24-25psi it might come close not sure. The 25 G makes about 500hp if tuned properly.
I say this from my experience with a TDo6H 20g that is laying on my workbench right now. I took it off and put my high flow back on because I had a broader powerband and higher peak power with the high flow. I purchased a freshly rebuilt Tdo6 with a Trust standard wastegate and ran it on a normal FC engine with a Power FC and a Profec B evc even boosting 1.1 I only could get 315RWHP out of it. I played with timing curves and was forever trying to get it to spool faster. The guys at KSP said that my Highflow turbine will flow more than the 20g and a 25g would be better but it will spool slower. After running a drift competition at Ebisu circuit I could not get a proper drift with the turbine so with all the combined problems I decided to swap back good ole High flow turbine.
Not to say that the td06 was a bad turbine I reallylike the way it pulls in the upper RPM ranges but I would need more tuning or maybe a port to get the spool I like and would have to run a lot more boost to get the power I want.
Old Dec 5, 2003 | 04:40 AM
XLR8's Avatar
60-1 .96 AR ceramic ball bearing
Old Dec 5, 2003 | 12:45 PM
edit..
Old Dec 5, 2003 | 02:50 PM
eViLRotor's Avatar
Oh oh...lol....
Old Dec 5, 2003 | 03:46 PM
edit...
Old Dec 5, 2003 | 04:19 PM
edit..
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
toplessFC3Sman
Mar 20, 2018 01:54 PM
R.O.D
34
Jan 6, 2016 12:09 AM
Vartok
16
Oct 8, 2015 04:49 PM
