lsd project please help???
Old Nov 29, 2003 | 06:35 PM
please help me.
i own a 1981 rx7 that has been running on a bad OPEN diff for over 4 years.i decided to finally fix this and went to the junk yard to pick one up.to my surprise i found a 1984 with rear disks and LSD.i was able to remove it completely with almost new tokiko shock absorbers all for 110 dollars.today i removed all of my rear suspension along with diff,everything seems that will work ,
EXCEPT THAT THIS DIFF HAS A DIFFERENT BOLT PATTERN ON THE DIFFS FLANGE.4 BOLT BUT WILL NOT MATCH MY DRIVESHAFTS BOLT PATTERN?WHAT CAN I DO???
IM DONE FOR THE DAY,I GOT TIRED OF WORKING ON THE CAR.WILL THIS HAVE DIFFERENT RIM SIZE??4 X 110 IS WHAT IM RUNNING....
Old Nov 29, 2003 | 06:44 PM
Felix Wankel's Avatar
Super Newbie
go back and get the driveshaft out of the same car. the bolt pattern on the pinion flange was changed in 83 or so.
Old Nov 29, 2003 | 07:00 PM
ONE PROBLEM.
THE CAR THAT THE LSD CAME OUT OFF WAS A 1984 WITH AN AUTOMATIC TRANS NOT A MANUAL.WILL THE DRIVESHAFT BE SHORTER OR LONGER.ALSO DOES ANYBODY KNOW IF IT MATTERS IF A LSD IS OUT OFF A MANUAL OR AUTOMATIC GEAR RATIO WISE>>>>WHATS BETTER.
Old Nov 29, 2003 | 07:01 PM
THANK YOU BUT I NEED A LITTLE MORE HELP..
Old Nov 29, 2003 | 07:05 PM
K-Tune's Avatar
FD Daily
hmm...
Old Nov 29, 2003 | 08:10 PM
beastiefromcinci's Avatar
Same Gear Ratio. A/T or Manual Trans.
Old Nov 29, 2003 | 08:12 PM
Check www.grannysspeedshop.com for specific ratio.
Old Nov 29, 2003 | 08:18 PM
Super Newbie
i think you have to get a 5 speed shaft.
Old Nov 29, 2003 | 08:23 PM
No it doesnt have to be a 5 speed shaft. I just did the swap last week. LSD from my autotrans to my manual trans open diff car.
Old Nov 29, 2003 | 08:25 PM
oops. yeah you prolly do need the 5 gear driveline.
Old Nov 29, 2003 | 08:36 PM
Rx7carl's Avatar
Airflow is my life
Youll need a manual driveshaft. Or you can swap over the yokes. But be forewarned, I dont reccomend this, although many others have done it without any problems.
Old Nov 29, 2003 | 09:09 PM
so for sure it has to be from a five speed tranny.....the drive shaft....thankx for all the help you guys..the rotary kicks assssss......= - )
Old Nov 29, 2003 | 09:10 PM
Super Newbie
yeah it has to be from an 83-85 too.
Old Nov 29, 2003 | 09:30 PM
QuagmireMan's Avatar
Registered Offender
Originally posted by FBDrifter
hmm...
lol
Old Nov 29, 2003 | 09:34 PM
was up with the cap pic???
Old Nov 29, 2003 | 09:39 PM
jsinrx7's Avatar
Flange is different, so is rim bolt pattern, and I think that the brake line thread is different.
Old Nov 29, 2003 | 10:22 PM
Super Newbie
uh, no.
Old Nov 29, 2003 | 10:24 PM
FD Racer's Avatar
sold the FD...kept the FB
I thought autos were all open diff
Old Nov 29, 2003 | 11:29 PM
slowautoxr's Avatar
autoxr/rallyxr
I don't think GSL-SE's came with automatics.
So assuming it was a GSL automatic than you still have the 4x110 wheel bolt pattern. The brake lines will work just fine. All you need as already mentioned is the driveshaft. You did get the e-brake cables with your rearend right?
Old Nov 29, 2003 | 11:33 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
lol you were typeing LIKE THIS... ITS ANNOYING
so he put up a friendly reminder where the caps key is lol.
Old Nov 30, 2003 | 02:31 AM
i did get the parking cable complete with brake handle.the lsd diff is installed in the car , i had no problems installing just the flange pattern....im going to the junk yard tommorow...
Wicked93gs
42
Oct 7, 2015 11:58 PM
