Found: 12A in Junkyard.......
Old Nov 20, 2003 | 09:12 PM
rotary_neubie's Avatar
Question Found: 12A in Junkyard.......
Today I found a 12A for $100 Canadian, with a carb, and possibly a tranny. I need a carb to rebuild, but..... its been sitting outside for 4 years, and is seased..... Does anybody have any ideas, is it worth it, or not? I could rebuild the carb off of that while I still drive this one. And eventually rebuild the engine, if that is possible. Or are both the carb and engine complete garbage if they sat outside for so long???
Old Nov 20, 2003 | 09:19 PM
bouis's Avatar
It depends on if they were exposed to the elements or not. The engine might be okay (try filling it with MMO or ATF and letting it sit for a while, then turning it with a pry bar), and the carb, though it almost certainly needs that rebuild, is pretty much indestructible.
Old Nov 20, 2003 | 09:32 PM
So thats not a bad deal if that carb is industructable, and can be rebuilt.. The engine was exposed to the elements, no oil fill cap or anything... Is it possible to tear down and rebuild it? Kinda as a side project...
Old Nov 20, 2003 | 09:38 PM
bouis's Avatar
It's possible, but I'd open it up and look at it before I started ordering parts. Engine rebuild kits are very expensive.
Old Nov 20, 2003 | 10:15 PM
But the carb should be rebuildable tho right?
Old Nov 20, 2003 | 10:17 PM
bouis's Avatar
Unless there's something wrong with it prima facie, yeah.
Old Nov 20, 2003 | 11:19 PM
Directfreak's Avatar
I am a Jeeper Now.
If it has rust inside, (99% sure based on what you describe) - then it's worthless.
Only good thing about it would be to take it apart, keep the nuts and bolts,
Practice porting with the plates
or
Make a clock out of the rotor or rotor-housing.
Old Nov 21, 2003 | 08:54 AM
heh... I dont believe that df.... I took a motor that sat for 6 years outside... in the elements.... degreased it... ran water through the motor.... (didnt budge turning over, seals easily let water through.... then poored a qt of atf in it for three days into any and every hole i could find....
and then i got it broken loose after three days... lots of crap coming out of exhaust port.... slight compression, if any.... stuck it in an 82 gsl.... got up to 50 mph with brother pushing in his sentra.... stuck it in second gear.... 20 seconds later it started.... ran the ***** out of it... as much as i could..... maybe 5 miles.... went home... atf'ed it over night.....
ran the hell out of it 5 more miles, went home... did a FULL tune up, then it started right up.... gave it back to the guy.... he's been driving it since...
went from a siezed POS to a nice smooth purring high compression 12a...... he has put atleast 10K since then... was well worth it for him.... new expirence for me....
Old Nov 21, 2003 | 08:55 AM
Are you refering to the carb or the engine being worthless?if the rotor housings and rotors have to be replaced when you rebuild, couldn't you sandblast the casing or whatever that holds the rotor housing? But anyways, the carb is what I am in need of, if that works, maybe thats all I will take. More opinions would be great.
Old Nov 21, 2003 | 09:30 AM
MarkPerez's Avatar
Tennis, anyone
what do you mean, maybe a tranny too ?? $ 100 dollors
is the going price for a rotory engine around here. Even if i were to find a 20b, the mexicans are,,,well stupid !!
Not everybody is rich like you DF,or officer freak,,,Lol
you forgot about the rotor housing fish tank. The only real way to kill a rotory engine is to run it dry of oil, then **** happens. but i'd say try to find an engine that had the hood on the car and maybe even an aircleaner on the carb still.
Old Nov 21, 2003 | 09:30 PM
I am a Jeeper Now.
You guys are Pissy.
Andrew - If the engine had water inside, it has rust. If it has rust, it ain't running. Your description is just of a sitting engine, not one that has been out getting water in it.
rotary_neubie - If the engine has rust, then all the seals, and bearings will be ****. The carb should be fine with a rebuild.
MarkPerez - That's "SIR" to you.
Old Nov 22, 2003 | 05:22 AM
MarkPerez's Avatar
Tennis, anyone
A carburator that is gummed up with old gas and crap is much better then one that is rusted inside.
Old Nov 22, 2003 | 01:17 PM
Cody's Avatar
SKELETOR!
Buy it, and take it apart. Hell, I bought a whole FC for $375 delivered to my house, just so I can take the engine apart and look at the rotors.
The car ran fine - which actually seemed to upset the junkyard owner.......I bought the car as it was dropped off, so they didn't have time to inspect it.
But, the mission was to strip the car anyways.......so I attacked it with all the tools I have.
I've still been making a profit on the vehicle despite the hundreds of dollars I have had to spend on more tools. It's a fun experience.
Andrew7dg
Aug 6, 2017 01:41 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
