Compression=103 w/100kish miles
Old Nov 13, 2003 | 06:30 PM
version13's Avatar
Exhaust leak
I ran a compression test on a t2 motor and got these numbers, I know that at about 90, its bad, and about 120 is brand new. So at about 100, how much longer until rebuild considering a nice daily driver?
Old Nov 13, 2003 | 07:39 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
those are good numbers. How long it will last is up to how you drive it and maintain it.
EDIT: How many miles on the engine?
Old Nov 13, 2003 | 07:41 PM
marcus219's Avatar
FC Mobsta
Compression is obviously a good thing, but I wouldnt say at 90k its rebuild time RIGHT AWAY..my buddy and I both ran our engines for a longgg time on about 90#'s on both rotors..they still pulled and ran good.
Oil changes, leting its see its powerand, and actually driving it will probably help the most.....
-Marc
Old Nov 13, 2003 | 08:45 PM
n4ji's Avatar
SPQR
Put in some MMO the next time you fill up. That stuff works wonders. Hope she lasts another 100k!
Old Nov 13, 2003 | 08:51 PM
marcus219's Avatar
FC Mobsta
My apologies..I can't belive I forgot about the mmo. I put that stuff in my used s4 6port before I put it in, I could see the carbon drip off my rotors...MMO IS THE ****!! Smells good too... :p
Old Nov 13, 2003 | 09:40 PM
version13's Avatar
Exhaust leak
MMO? What is "MMO" and where can i get this mysterious magical element?
Old Nov 13, 2003 | 09:50 PM
n4ji's Avatar
SPQR
You got one word... It's the almighty Marvel Mystery Oil! It's in a red bottle and you can buy it at Auto Zone or Advanced Auto parts. It's two cycle engine oil and does wonders for rotaries... and lawnmowers!
Old Nov 13, 2003 | 11:08 PM
13bpower's Avatar
s4 for life
When I got my T2 stock with 113k it was sitting at 100 on both rotors. I'm confident mine will last another 20k. If you keep it stock and maintain it well it could easily last till 150k.
Old Nov 13, 2003 | 11:15 PM
Pinfield357's Avatar
Originally posted by n4ji
It's two cycle engine oil and does wonders for rotaries!
IT IS NOT TWO CYCLE ENGINE OIL! and do not use it as such
it is a fuel system cleaner with lubricant in it (basically kerosen)
it can be used in the fuel system i was running about 4oz to a tankfull before i removed my OMP
or it can be used in your oil use the whole quart on your next change i never did this cause it seems like ti would thin out the oil alot
Old Nov 14, 2003 | 12:15 AM
Saku's Avatar
my compression was 69-70 all around and the Mazda mechanic(shop foreman) said that is 'normal/ok' on paper and when I asked him he said it was perfect....is he stupid?
Old Nov 14, 2003 | 01:03 AM
Rpeck's Avatar
What R U thinking self?
Yes, yes he is. Is it running okay? with those numbers I would think it would run like ****, if at all. My guess if it's running decent is he performed the compression check incorectly.
-Robert
Old Nov 14, 2003 | 01:07 AM
I believe the FSM states that 85 is the lowest acceptable number.
Old Nov 14, 2003 | 01:17 AM
13bpower's Avatar
s4 for life
If he said 6.9-7.0 it would be a different story. Those are the type of numbers a rotary specific compression checker spits out.
rxmiles
Aug 24, 2015 02:07 PM
elfking
Aug 19, 2015 09:48 PM
ncds_fc
Aug 15, 2015 10:06 AM
