Total Advance
Old Nov 7, 2003 | 11:17 AM
racintang's Avatar
Total Advance
I had no luck on the search and I know it's been posted before. I am looking for a total advance timing and the RPM at which it shold be. I can't get my car below 1000 rpm even after warmup. No carb and intake and from RB with an open exhaust 12A (1980). I set my timing ABOUT 2 DEGREES advanced since I could not get it down to 750rpm. Will that do? Yes, the idle screw is all the way in.
Old Nov 7, 2003 | 11:20 AM
brianw's Avatar
LET ME KNOW if you find this out I have the same problem. Even at 1000 rpm it dies from time to time when I come to a stop.
Old Nov 7, 2003 | 03:13 PM
Rx7carl's Avatar
Airflow is my life
Total should be 24L 16T. Thats above 4k rpm's.
Old Nov 7, 2003 | 04:34 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Different things can cause this.
Some fixes:
1. Raise the floats 1mm so there will be a little more fuel in the float bowl. This will set the fuel in the float bowl glass to just a hair above center. When you come to a stop fuel sloshes around the float bowl and the fuel jets could go dry and stall the motor.
2. Clean and/or rebuild carb. Run some gumout fuel system cleaner in the fuel tank.
3. Need a tuneup.
4. Vacuum leaks.
Old Nov 7, 2003 | 07:41 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
24 degrees BTC on the leading is correct, but at 6000 rpm. I can't find a reference to 16 degrees trailing in any of my references. Racing Bleat says 5 degrees for the trailing with 24 degrees of leading, but I should add that this is for a bridge-ported motor with open exhaust.
Old Nov 7, 2003 | 08:16 PM
wwilliam54's Avatar
it WILL run
check you fuel filter
mine idles and runs rough from a clogged gastank inlet
Old Nov 8, 2003 | 07:14 AM
Rx7carl's Avatar
Airflow is my life
6K? All the advance is done by 4K. WHat info are you using WG?
Old Nov 8, 2003 | 11:56 AM
Wankelguy's Avatar
That came from my 1985 Racing Bleat catalog.
6K is what it said, I suppose some of the info may have been revised since 1985, but I still think it's a valuable reference as it's focus is entirely on the early stuff.
So you are saying that the vacuum and mechanical advance in the distributor is maxed-out by 4000 rpm?
Old Nov 8, 2003 | 12:15 PM
Rx7carl's Avatar
Airflow is my life
Yup, on a 1st gen 12A anyhow. Actually it maxes out at like 3600 IIRC. Have you ever verified it? It works that way on both my cars.
Old Nov 8, 2003 | 06:33 PM
Wankelguy's Avatar
I'm not doubting you, I know for a fact that RB fudged a little in favor of surety in the early years. Running the motor up to 6000 rpm certainly makes damn sure that it's at full advance, eh?
Old Nov 8, 2003 | 09:18 PM
Rx7carl's Avatar
Airflow is my life
Certainly does now doesnt it.
Rotate86
May 18, 2018 02:44 PM
Sethix
Nov 3, 2017 11:48 PM
SRTx781
Dec 19, 2015 07:30 PM
James Knox
Oct 5, 2015 07:56 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
