Front Strut Tower upgrade?
Old Oct 9, 2003 | 02:47 PM
KaiNalu's Avatar
I have a '79. Recently I purchased the strut towers off of a '85 GSL. I am doing the upgrade so that I would have the option for adjustable shocks in the front. Well my problem is that I have already purchased crossed drilled rotors to fit the '79 and stainless steel brake lines to fit the older thread. So in hopes that I can still use them I want to mount a '80 piston style caliper to the '85 strut tower and use my cross drilled rotors. I have two problems. One have no idea if the '80 style caliper will match up and the bearings are different on the '85 hub. Has anyone come across this before and is it possible? Thanks in advance, Bob
Old Oct 9, 2003 | 05:00 PM
kuhlrx7's Avatar
Unconfirmed
what? did you, hun?? ss lines fitting rotors?barings differant79/80/85 what???? take a breath, stop, re type your question and be clearer. no one will know what you are asking !!!!!!!!!!!!
Old Oct 9, 2003 | 05:40 PM
'85 GSL 302's Avatar
I'm kind of lost too but here's what I can tell you. The 84-85 hubs use larger spindles so a 79-80 rotor will not fit. I see no reason the 85 strut tower won't work, have you tried it?
Are you talking about stut towers as in the brace that goes accross your motor, or are you refering to the wheel hubs that the brake calipers mount to? Your wording is confusing.
peejay's Avatar
Old [Sch|F]ool
Yeah, really, take deep breath and restate.
To make things easier, strut towers are the part of the body that the struts bolt to.
Snoopy FD
Dec 8, 2015 01:45 PM
rkhanso
Aug 13, 2015 11:40 AM
