1980 header installation
Old Oct 1, 2003 | 03:16 PM
I'm considering installing a header for my 1980 RX7. It has the heat exchanger and I am wondering the best way to install the header. Looks like the heat exchanger has hoses running to and from it.
Old Oct 1, 2003 | 03:50 PM
seanrot's Avatar
Always waiting for parts!
buy this click to header auction and remove emissions. this will bolt up no problems.
Old Oct 1, 2003 | 06:45 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
The RB headers in seanrot's link bolt right up, like he says. There are a couple of other things you need to do when you install a header, however. The air pump and ACV have to be removed, and block-off plates made to ensure there are no vaccum leaks. I made mine out of aluminum. Once the air pump is removed, you will need to buy a short belt that will run the water pump, because it will not run properly with the partial contact from the alternator belt. You can get the proper belt from NAPA, pn# 7215.
I did the same thing a few months ago, and I have some advice...
Get a different muffler. The exhaust note is very high-pitched and tinny with the headers running into the restrictive stock muffler. I'm looking at a Magnaflow myself, but if you have the coin, the RB Primaflow is the best muffler you can get.
Old Oct 1, 2003 | 07:01 PM
is it easy to find the gasket to fit the header?
I have to admit that I am a newbie to the RX7. I just have to remove those two items and fab some plates? What if I didn't want to make them? Is there a place that does? Would removing those two parts require me to change any settings with the motor?
thanks for the help!
Old Oct 1, 2003 | 07:38 PM
seanrot's Avatar
I have one to go witht the auction if you need it.
Old Oct 1, 2003 | 10:55 PM
MosesX605's Avatar
I could have sworn that Racing Beat offered block-off plates, but now I can't find them on the website. No big deal, IMHO. All you need to do is trace the shape onto some aluminum, cut to size and use some make a gasket to seal it up. Ideally, once you remove the air pump and ACV, you should remove all the other emissions equipment, but I haven't yet, and my car runs fine. If you don't feel up to it, you don't have to tackle the rats nest. I haven't altered any other settings.
Old Oct 2, 2003 | 10:31 AM
I found a vendor for the plate and it is $6. Since I have an 80 model. Do I really need the presilencer?
Old Oct 2, 2003 | 10:53 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
If you get the mini-presilencer, it will bolt right up to the stock pipe, and it won't sound tinny. More like RASPY, lol.
I'm pretty sure Mazdatrix sells all the block off plates needed. There is one for the heat exchanger tube on the rear of the intake manifold, and one for the ACV on the side of the intake manifold.
And you don't need to run an extra belt, just use a high quality belt like Gates, and keep it tight.
Old Oct 2, 2003 | 01:51 PM
well, they have both plates for $6 each. Thanks for the help!
Snook
14
Oct 1, 2015 10:56 AM
apooch
Sep 4, 2015 10:27 AM
