Turbo II engine guys: how do I hook up the throttle??
Old Oct 1, 2003 | 03:10 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I searched and couldnt find how to hook up the throttle cable to the TII trottle body.
Forgive me, I dont know the proper terminology for some of these parts.
Starting with the throttle cable, it has to be attached to the manifold, the cable holder gets super close to the firewall, plus it doesnt really look like it will work. Im thinking of having the cable holder in front of the TB instead of on the mani, making the cable not have to bend as much.
Second, do I just have to put a Nikki, throttle linkage on the TII TB to make it work???
Help me out here.
Old Oct 1, 2003 | 04:58 PM
hornbm's Avatar
FD > FB > FC
You have to use a FC throttle cable. The nikki one will NOT work.
Old Oct 1, 2003 | 04:59 PM
damn, how hard is it to install the fc cable?
Old Oct 1, 2003 | 05:22 PM
XLR8's Avatar
Will a SE cable work?
Old Oct 1, 2003 | 05:49 PM
hornbm's Avatar
FD > FB > FC
the SE one will not work. The FC one goes right in. Its a direct replacement. It looks just like the 1st gen one only alot shorter. Takes 2 minutes max to install.
Old Oct 1, 2003 | 06:23 PM
10sec rx7's Avatar
you should have room on the upper mani to install a cable bracket, did you move the 13b foward?? usually we will drill another hole in the engine crossmember to move the motor foward a inch, this gived plenty of room at the back for the throttle cables etc,
Dale
Old Oct 1, 2003 | 06:44 PM
hornbm's Avatar
FD > FB > FC
actually the problem is really with the stock 1st gen cable itself. when you mount it there is not enough slack to reach the throttle without pulling it more than half way open.
Again you dont need a bracket, just a throttle cable from a FC. It cost me about 10 bucks from a junkyard. Works PERFECTLY.
Old Oct 1, 2003 | 08:59 PM
i have the racingbeat, 12a to 13b engine mount
alright, just gotta get a FC cable then
Old Oct 1, 2003 | 10:34 PM
Felix Wankel's Avatar
Super Newbie
turbo and non turbo cables are different, you'll probably need a turbo one. it's like 50 times longer.
Old Oct 1, 2003 | 11:04 PM
luiml73's Avatar
Rotary Powered Boobies
I thik you need the T2 cable, that's what I went with. The only small broblem I had was about an inch of play on the foot pedal. I just rigged a spacer an it worked like a charm.
Old Oct 2, 2003 | 05:23 AM
XLR8's Avatar
Thanks guys. .......baby steps
Old Oct 2, 2003 | 02:12 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Are you sure? Mine works on a cosmo TB
I just cut the TB where the throttle cable goes on, made it flat instead of the little loopy thing it does, tightened the cable and it works
sarch I think i posted a pic of it.
Old Oct 2, 2003 | 02:20 PM
MIKE-P-28's Avatar
here ya go
Old Oct 2, 2003 | 05:33 PM
Directfreak's Avatar
I am a Jeeper Now.
The Cosmo Throttlebody Lever is on the same side as the FB, thus it is easier.
I am using an FD throttlebody and it is on the Other sde of the intake, so I had to get a TII throttle cable. Much longer and wraps around.
I am sure his TII throttlebody is the same.
Old Oct 2, 2003 | 06:10 PM
RotorMotorDriver's Avatar
Seven Is Coming
So, to make the throttle cable work on the T2 engine you need the T2 throtle cable, right? Is that what weve concluded?
~T.J.
Old Oct 2, 2003 | 07:25 PM
Super Newbie
actually the TII one is like the Cosmo one, but when you don't have the cable looping around like it's supposed to, you can get by with the short one. Looks like a pain to get it to where it has WOT though.
Old Oct 2, 2003 | 08:37 PM
I am a Jeeper Now.
It's not just that the throttlebody cable lever is on the opposite side, but it opens in the OPPOSITE direction as well.
I know, I could've used the stock FB throttle cable with the Cosmo Intake.
However, the TII and FD throttlebody levers face the opposite way as well, so you need the longer cable to pull it from the other direction.
immanuel__7
89
Sep 5, 2015 10:23 AM
Engine stand ready
Aug 14, 2015 10:26 PM
