would like to upgrade to 1300cc secondary
Old Sep 30, 2003 | 12:07 AM
tekno62's Avatar
I have a warbo 255 fuel pump ( not installed ).. I would like to know what I need to do to my fuel system to go to 1300cc secondarys.. I plan on keeping the primary 550 cc..
Old Sep 30, 2003 | 12:15 AM
rynberg's Avatar
Get your stock secondaries bored out by RC Engineering to 1300cc. Reinstall the injectors. Make adjustments to your PFC or other stand-alone ecu. You're done. Chris Regan has a nice write-up on his site:
http://www.negative-camber.org/crispyrx7/1300.htm
Old Sep 30, 2003 | 02:41 AM
twinturboy's Avatar
Just wondering how much it costs to bore out the secondary injectors, does anyone know. Also how much does rc charge to balance and blueprint the stock injectors?
Old Sep 30, 2003 | 07:30 AM
Mahjik's Avatar
Mr. Links
http://www.rceng.com/index.htm
Old Sep 30, 2003 | 02:17 PM
twinturboy's Avatar
cool thanks...
Old Sep 30, 2003 | 10:05 PM
93blackrx's Avatar
I sent mine there and they did a great job. I think it was allmost two hundered each to get them done.
Old Oct 1, 2003 | 12:31 AM
GsrSol's Avatar
Z06 powered FD
You will need a stand alone type ecu to run them if you don't already. A chipped ecu (M2, Pettit) won't know that you switched them and will still flow at the same rate and flood the motor.
Old Oct 1, 2003 | 01:15 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
word on the street says those injectors popped a couple of my motors... you could search... I'm not the only one.
Old Oct 1, 2003 | 06:13 AM
rxrotary2_7's Avatar
i believe this is the thread you are refering to Ryker. https://www.rx7club.com/forum/showth...hreadid=219098
look here for one place to get the alternative 1600 setup. http://www.3rdgenrx7.com/keithsrails.htm
Old Oct 1, 2003 | 07:32 AM
weaklink's Avatar
Resident Retard
I have bored out RC injectors (850s to 1300s). I have had zero problems. I bought mine from http://www.rxecret7.com/index.html so that there would be no turn around time.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
