View Poll Results: Have you experienced 1300cc injector failure?
My 1300cc injectors have failed.
13
19.40%
My 1300cc injectors have not failed.
54
80.60%
Voters: 67. You may not vote on this poll
1300cc RC injector failure poll RECOUNT
Old Aug 29, 2003 | 10:38 AM
CCarlisi's Avatar
Rebreaking things
Due to complaints filed by CA forum residents we are going to have a recount with less ambiguous ballots.
I believe the problem with, "have they failed, YES or NO," was that the question could not be answered correctly without reading . . .the question!
The new poll:
If anybody is unsure of which choice to pick please contact me. I have again refrained from using a long list of answer choices for fear of making it confusing and or tedious. However, if anybody would like to also post mileage and max duty cycle information please do so.
If the mod could please flush the last thread on this subject I would appreciate it.
Old Aug 29, 2003 | 12:37 PM
SERIES7's Avatar
Embassador to SOY
I got my RC bored out 1300cc injectors through RotaryXecret7 and they have worked fine. Hopefully they will continue to do so. RC even provided me with a flow chart to let me know what my injectors are shootin at. One of them reads 1298cc and the other read 1302cc.
Old Aug 29, 2003 | 07:18 PM
voodooracing's Avatar
its kinda depends on a lot of things... I have seen people sending in old and poor condition injectors and get bored out. Those will probably be more likely to fail. But if the condition is good, they shouldn't fail that frequent.
Old Aug 29, 2003 | 08:59 PM
DaedelGT's Avatar
Uber Newb.
It was said in the other thread that they are not bored at RC, I believe.
Old Aug 29, 2003 | 11:40 PM
CCarlisi's Avatar
Rebreaking things
Old Aug 30, 2003 | 01:45 PM
Radical Rotary Avantgard's Avatar
Sleeper
Cool
32 people have voted that their 1300 cc have failed meanwhile nobody has posted the story.
I still think they are voting based on "I heard a story from a friend........
That is the reason why I went with 1200 cc, PANIC from the so much talked about horror stories.
1300 cc failure Fact or Fiction???
Oh, and I did not vote on the poll.
Old Sep 2, 2003 | 02:05 PM
wonder1and's Avatar
I Sold My Car 2 the Devil
Fact. I'm on my 4th motor since they were sticking shut...
Old Sep 2, 2003 | 09:46 PM
Tim Benton's Avatar
FD title holder since 94
My 1200 are working fine, no motor replacement for me. Wonderland, after the first motor let go, then the second, then the 3rd, what were you checking to see what the cause was that made the engines let go?
Tim
Old Sep 3, 2003 | 02:50 PM
wonder1and's Avatar
Well when RP installed them they were leaking and flooding the engine... the original tuning put my at 425 rwhp on my old T04S... then at 390~ running real rich then mid 300's on 10lbs of boost... but the thing was... my last motor let go after pulling away from my friends house... just getting past the switch from primary to secondary... and I didn't have time to even build full boost. So by process of elimination... it wasn't any twin turbo switching system b.s. since I wasn't using any of it... wasn't the tuning b/c by the time the last motor rolled around if was running a 8-9.0 AFR aka REAL RICH... it wasn't the turbo b/c i didn't even build boost when my last motor let go around 1k after being built... couldn't be bad gas b/c I bought gas in 2 completley different cities... and also I switched my injectors after my last motor and now my motor has lasted 20k w/ 850's all around... now I'm on 850/1600 setup.
Problem solved.
Old Sep 3, 2003 | 04:48 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Did you do any testing to confirm the injectors were actually sticking or was it just based on a process or elimination or the fact that you havent had any prob's with the new engine/injector set up? When you swaped engines/injectors didnt you have the new setup retuned? Especially since you changed injector size.
Were they 1200 or 1300?
STEPHEN
Old Sep 3, 2003 | 05:02 PM
the_glass_man's Avatar
Will u do me a kindness?
1300 Secondaries for about 25,000 miles, not a single problem.
Old Sep 11, 2003 | 12:00 PM
Mr rx-7 tt's Avatar
rotary sensei
6 of us around here with 1300's no problems with any of ours...knock on wood.
Old Sep 11, 2003 | 01:46 PM
lerch32's Avatar
I have set for sale, if anyone is looking to buy some.
Old Sep 12, 2003 | 09:52 AM
wonder1and's Avatar
STEPHEN
Process of elimination... swapped them and have not popped a motor since. I had the 1300 setup retuned 3-4 times by RP's tuner. Then swapped to 850's and then retuned for those to go in.
Old Nov 5, 2003 | 12:40 AM
badass7's Avatar
Pimpin Rotors...and Hoes
Is there such a thing as a Brand New Mazda 1300cc injector ?? Someone is claiming that they have brand new 1300cc injectors from Mazda and that they aren't bored out RC Engineering ones. I have never heard of that, but then again.....I really don't know.
Old Nov 5, 2003 | 01:36 AM
wonder1and's Avatar
Never heard of them... I doubt it. Need more fuel...? Catch up w/ Rx_... he'll set you up!
-Ryker
Old Nov 5, 2003 | 01:42 PM
rynberg's Avatar
SR Motorsports sells "new" 1300cc injectors. What that means is that they have brand new 850cc injectors bored out instead of using your old ones.
Considering how many FD owners have upgraded their fuel systems, I highly doubt there are off-the-shelf 1300cc injectors that fit into the stock fuel rail.
Old Nov 5, 2003 | 06:06 PM
rxrotary2_7's Avatar
also considering the rate of failure i dont know why/who would trust a perfectly good motor to them. even if only 10 people have had motors pop out of 48 that voted so far, is it realy worth the few bucks you will save over a 1600 set up?
Old Nov 5, 2003 | 06:20 PM
7racer's Avatar
what is it with 1300???
aren't other sizes like 1200 bored out the same way by RC??? However, we don't hear nearly the same amount of problems with failures.
Old Nov 5, 2003 | 10:14 PM
badass7's Avatar
SOOOO, even the BRAND NEW 850's bored out to 1300's are prone to failure or is that just an issue with with the 10 yr. old injectors being bored out ?? I def. don't want to run into fuel probs. with my single turbo at 15 psi. I'm thinking I should be alright with the New ones bored out...............
Old Nov 5, 2003 | 11:08 PM
Trout2's Avatar
RC prefers to only bore new injectors or very low milage ones.
Jack
Old Nov 6, 2003 | 09:36 AM
I have run the 1300's for almost two years
without problems.I think alot of guys out
there have blown motors because there fuel
system couldn't keep up with there injectors, and blame it on the 1300's.Another good thread would be, how
many out there have a good accurate fuel
pressure gauge installed in front of them!
Old Nov 6, 2003 | 10:44 AM
rynberg's Avatar
Because some of us have to pass emissions and still run the air pump. You don't have to remove the ACV to run 1300cc injectors. You can also still run the stock FPR and not have to replumb your whole damn fuel system. That said, if I had a single turbo car in a no-emissions testing state, I wouldn't mess around with bored out injectors either.
In any case, I agree with your point. I believe my mechanic won't even install 1300cc injectors, but will install 1200cc injectors (that's second hand though as I still have the stock 850cc). Apparently, the injectors bored out to 1200cc are much more reliable.
Old Nov 6, 2003 | 11:22 AM
not having to deal with emissions.... i didnt think of that.
Old Nov 13, 2003 | 06:37 AM
jeff48's Avatar
Rotorally Challenged
Let's try a new poll.
Failure of stock injectors. See new thread here.
