keeping engine warm...
Old Sep 29, 2003 | 01:56 AM
FB II's Avatar
ok, winter is almost here and i really hate how my car stays freakin cold. now i do the little block the airflow to the radiator trick and that works while i'm driving, but how can i keep my engine bay warm i guess, so when i come back to the car 20 minutes later i dont have to hold the choke. ? any ideas? hahaha
Old Sep 29, 2003 | 01:58 AM
TheTwinTurboRX-7's Avatar
get a block heater, not that expensive and very easy to install
Old Sep 29, 2003 | 01:59 AM
FB II's Avatar
really??? hell yea! where can i get that from? hahaha! i'll check summit. how exactly does that work?
Old Sep 29, 2003 | 02:19 AM
FB II's Avatar
k, think i may have found what i am looking for?? how does this work, and i dont want to have to plug my motor in to the wall every time i park. LOL
jegs heaters and faceula
Old Sep 29, 2003 | 04:05 AM
peejay's Avatar
Old [Sch|F]ool
hold the choke? whyfor? the engine shouldn't cool down that much in 20 minutes.
Old Sep 29, 2003 | 04:35 AM
if you get a block heater you do have to plug it in, that is how it works, you plug the car in and it circulates the water through the block and through the electrical coils in the heater keeping the water warm.
Old Sep 29, 2003 | 01:31 PM
FB II's Avatar
ok, that will work well for the mornings. :P:
peejay; when its 20 derees here it doesnt take long at all for me to have to need the choke. and since my choke wont stay out i have to hold it. and that is just annoying.
Old Sep 29, 2003 | 02:24 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Switch to an electric fan with a thermostat that way when she gets restarted it won't blow cold air thru the radiator and oil cooler, which makes it take longer to warm back up.
Old Sep 29, 2003 | 04:03 PM
mar3's Avatar
Administrator
Here is the lowest tech answer you can get that will work and it will only cost you a dime...actually, you just use that freakin' dime to prop the choke open inside the car. Pull the choke ****, stick the dime in there and let it close on it. The dime has the smallest diameter of all American coins and it's about a 1500 rpm idle with that shadetree trick. At least it was for my '79 and '80...
And to all the coin guys out there that will now correct me or try to, you can bite my shorts right now, haters...
Old Sep 29, 2003 | 06:45 PM
RotorMotorDriver's Avatar
Seven Is Coming
You can use a small piece of rubber hose split down the side to hold it open too .
~T.J.
Old Sep 29, 2003 | 06:56 PM
DriveFast7's Avatar
I've used a binder clip to hold the choke open.
Old Sep 30, 2003 | 01:27 AM
FB II's Avatar
lol, awesome. i'll do that then! hahaha
Old Sep 30, 2003 | 07:49 AM
Rx7carl's Avatar
Airflow is my life
Old Sep 30, 2003 | 11:22 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
electric fan helps alot in the cold for quick warmups
Old Sep 30, 2003 | 02:11 PM
NanaimoRx-7's Avatar
I keep a penny, a dime and a quater in my change slot for varying weather conditions. I lost the magnetic choke when I used the sensor hole for my water temp sensor. Works fine.
Old Sep 30, 2003 | 05:45 PM
but.. in winter here are about -5 °C -10°C to 0 °C but in winter winter not now..
need i 10W30 OIL or no? thanks,
streetlegal?
Mar 17, 2022 02:46 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
rx7jocke
Aug 15, 2015 03:36 PM
