Bass frequency??anyone know which is best
Old Sep 25, 2001 | 08:28 PM
CanadianRX7's Avatar
i have the alpine cdm-7861 deck with 2 sws-1040 and a
mrv-100m amp
it says on my deck i can change the frequency from 60,80,100,200
which is the best??
i want more deep loud bass
Old Sep 25, 2001 | 09:12 PM
loudazzrx7's Avatar
C-town Hustler!
only one
if you want the best sound and deep bass from all music --keep it at 80-------for real
Old Sep 25, 2001 | 11:08 PM
aiight
thats what it is at right now thanx
Old Sep 25, 2001 | 11:26 PM
Icemark's Avatar
I am assuming you are talking about the bass adjustment point for the bass control, and not the built in sub X-over on the deck?
What sort of enclosure do you have the sub(s) mounted in?
Old Sep 26, 2001 | 05:10 PM
yes i am
its a ported box with the 2 10's in it
Old Sep 26, 2001 | 05:33 PM
Icemark's Avatar
I would set it at 60 or 80, depending on your x-over...
60 will give you lower bass, 80 or 100 will give you louder bass.
Unless you don't have any mid range then I wouldn't set it up to 120.
Old Sep 27, 2001 | 12:25 AM
spyfish007's Avatar
Yellow Dragon is no more
By running it @ 60 Hz you will be able to turn up the gain on your amps and drive them harder so your low and ultra low Bass notes will increase in SPL because you are not wasting as much amp on the 60 to 80 range. It will also make your subs a little tighter sounding on those bass drum kicks ... don't worry the R&B/Rap stuff will still booooom!!
Old Sep 27, 2001 | 12:18 PM
okay thanx for all that help
good rap is all i listen to basically
Old Sep 27, 2001 | 02:13 PM
Icemark's Avatar
Spyfish:
What you said only works on X overs, its not applicable to variable boost centers (or equalization) as in this case.
Shainiac
Jul 17, 2019 02:20 PM
RyanFox
Sep 18, 2015 09:09 PM
20B Forum
Aug 30, 2015 12:08 AM
DuCeY DuCe
Interior / Exterior / Audio
Dec 25, 2001 05:04 PM
vobs
Aug 3, 2001 04:13 AM
