engine problems, parts needed/identified, any input is welcome, Aspec maybe?
Old Sep 23, 2003 | 03:37 PM
In this pic, there is actually a one way valve off of the screen, you can see a little tip of it in the part that is circled, it has "9h26" written on it, as does the one way valve in the green square. Would this mean that they are interchangeable? What would the part code on the one that is off the screen be? The dealer needs to know the exact number before they'll order the part, if you could look on your FD or know engines well could you inform me a little bit. The guys from A-Spec might be of some help to me here as well.
Another problem that I have is that I just bought 2 used turbo p/c and wastegate solenoids and I want to replace them. I took my UIM off a week or 2 ago, and therefore, had to undo the clips, my clips do not have the dots they are supposed to, one has a white splash of paint and the other has a yellowish white splash which could have originally been white but just changed over time. Is there anyway that I can tell these clips apart to make sure they go into the right solenoid? The solenoids wouldn't be interchangeable I'd imagine... but if they are could you let me know? The solenoids seem to do opposite things so I'd thing the motor would blow if they were interchanged. A Spec any thoughts on this or am I just gonna have to trace the wires? [IMG]C:\WINDOWS\Desktop\vacuum hose2 edit.bmp[/IMG]
Old Sep 23, 2003 | 03:40 PM
Rx-7$4$me's Avatar
Where are you in chicago? Also you cant link a pic from your hard drive you have to upload it somewhere on the net.
Old Sep 23, 2003 | 03:53 PM
93blackrx's Avatar
where is the pic?
Old Sep 23, 2003 | 04:12 PM
http://www.imagestation.com/mypictur...0hose2%20edit2
Go there please. It's the pic. BTW, the solenoid question has been solved. I overlooked brown tape on the W/G harness. brown tape to brown solenoid... it kinda makes sense lol, maybe these people at Mazda had a good idea or two after all...
Old Sep 23, 2003 | 04:19 PM
this is pissing me off....
Old Sep 23, 2003 | 04:23 PM
http://www.imagestation.com/album/?id=4289905767
99.99% sure this will be right, thank you for your help and patience...
Old Sep 23, 2003 | 04:24 PM
It's the last pic of the album, but sure enough it's in there!!!
Old Sep 23, 2003 | 04:27 PM
I fixed it, it's the first pic for whomever is trying to help's convenience.
Old Sep 23, 2003 | 08:24 PM
vel525's Avatar
Woo Hoo, It Runs!!
damn royce you're having some issues..lol. your car gonna be up and running soon?
Old Sep 23, 2003 | 09:40 PM
Lol, yep, this is the last part that I need and the UIM goes back on. Hopefully I can get the part by Friday so I can put the motor together and have it by the weekend, I want to drive my baby!!!! I'm dyin' over here
Old Sep 24, 2003 | 02:51 PM
Can someone give me any kind of insight on this??? PLEASE!!!
Old Sep 27, 2003 | 03:19 AM
My problems have been solved... after replacing some solenoids and clips I put my motor back together and voila!!! It works great now. I needed a new battery too, but that's irrelevant. Although I am getting some boost spike, I have it set at .55 bar, but it's spiking to .85 whenever I get on the gas...
JZW
3rd Gen General Discussion
29
Dec 21, 2016 11:23 AM
jase03
Aug 20, 2015 02:09 AM
rx7jocke
Aug 15, 2015 03:36 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
