wheres sparky?
Old Sep 18, 2003 | 07:37 PM
stevensimon's Avatar
wheres sparky?
i will give you guys a little history first. friday my rx got towed because the land lady doesnt like it there, so monday i got it out of the impound lot. the yard lost my battery, and somehow managed to destroy the interior. i got a new battery and it wouldnt even turn over. i found that the main fuse was fried, so i replaced it. now it cranks but i think that i dont have spark. it wont light up a timing light. i know it is losing the power before it reaches the coils, because i tested after the fuse block and it was good. i couldnt get the light to light when i was touching the lead to where the coils plug in. is there an inline fuse between the main fuse block and the coils? any help would be awsome. thanks guys.
Old Sep 18, 2003 | 07:49 PM
J-Rat's Avatar
Alcohol Fueled!
Time to sue the impound company... They probably crossed the polarity on your battery and fried your car.
Jarrett
Old Sep 18, 2003 | 08:09 PM
I will second that! Don't let them get away with destroying your property- period.
Old Sep 18, 2003 | 08:33 PM
so if the polls were crossed, what happened? is the comp fried or just a burned wire or hopefully a fuse.
Old Sep 19, 2003 | 05:19 PM
im still working on this, does anyone have any more info?
Old Sep 19, 2003 | 06:00 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
It could have shorted alot of things in the car, mainly the ecu.
Old Sep 19, 2003 | 07:51 PM
well i brought my all knowing frined bill over to check it out. there is powa to the coils but whatever tells them to spark, isnt doing its job. what would most likely be it? would it be the timing distributor thing? how does the spark work on these cars?
Old Sep 19, 2003 | 07:53 PM
J-Rat's Avatar
Alcohol Fueled!
The CAS would control it, along with the ECU.
Old Sep 19, 2003 | 08:33 PM
ok i checked to see if the cas was getting any electricity. its not. i unplugged it and checked all 4 connectors, nothing. while my friend turned the key i checked them again, still nothing. on the top coil pack there is a green wire and another one. the green wire is hot, what does the other one do? how does the ecu control spark? i didnt think it handled it.
Old Sep 19, 2003 | 09:48 PM
novicaine's Avatar
steven my t2 is showing the exact same symptoms of no spark with power at the coils but notta at the cas. Hopefully someone can fill us in!!
Old Sep 19, 2003 | 10:37 PM
i sure hope so, there isnt much SCCA action left.
Old Sep 20, 2003 | 04:00 AM
c-squared's Avatar
Two possible scenario's: BAD CAS, and more likely, fried ECU.
Bust out the wiring diagrams and trace this with a DMM. No one is going to be able to tell you EXACTLY what the problem is. Everyone can offer merely guesses. An hour's worth of testing will save thousands of words in guesses.
Old Sep 20, 2003 | 12:33 PM
where do i get wiring diagrams? second whats a dmm? oh digital multi meter?
Old Sep 20, 2003 | 02:32 PM
www.fc3s.org for online manuals and yes it is a digital multimeter
Old Sep 20, 2003 | 08:28 PM
cool, i will do that. there is a rotary mechanic thats going to help me later.
Old Sep 20, 2003 | 08:47 PM
fc3seeker's Avatar
T2 Noob.
I just got thru a prob similiar and it turned out to be teh crank angle sensor, so I second the CAS
Old Sep 22, 2003 | 11:58 PM
is there a way to check the cas? where is the ignition switch at? what ohms are the ign. coils supposed to read? is there a way to check the ecu?
Old Sep 23, 2003 | 12:52 AM
Check Cas = FSM, Section 4A- Pg 52
Ignition Switch= Steering Column
Coil Resistance= .02 to 1.0 ohms
good luck
Bitchn7
Apr 1, 2014 10:02 AM
rotary#10
West RX-7 Forum
Jun 19, 2013 03:28 PM
rotary#10
West RX-7 Forum
15
Jun 20, 2011 11:41 AM
SuperRotorMan
Jun 30, 2007 01:54 PM
