Greddy Water Temperture Sender Unit
Old Sep 18, 2003 | 04:20 PM
silverrotor's Avatar
Are you guys tapping It In the Water Pump without the adapter fitting? I'm In favour of doing this. As a back up, I have a brass fitting adapter. I'm not sure about the compatibility of aluminum/brass either.
Old Sep 18, 2003 | 10:39 PM
I'm opting to ditch the brass fitting. Are you guys using the optional adapter fitting or tapping the Sensor In straight Into the Water Pump Housing/Thermostat?
Old Sep 18, 2003 | 11:41 PM
neevosh's Avatar
The Dude Abides
I just put mine in the stock location. Seems accurate. I can see the thermostat open at around 83C.
Old Sep 19, 2003 | 12:26 AM
Davidov's Avatar
The GReddy sender won't fit in the stock location if you have an S4.
I came up with a cheap solution that has treated me right so far.
Just get a 3-4" length of 1.5" aluminum piping, thread the top with a 10mm threader, screw in the the GReddy sender, JB Weld it on, then stick it in the upper radiator hose.
The only downside is that it's after the Thermostat, but it beats taking off the waterpump.
Old Sep 19, 2003 | 05:30 AM
Fortunately for me, I have the option of tapping Into the Water Pump Housing due to it being off.
Old Sep 19, 2003 | 10:37 AM
Ni5mo180SX's Avatar
White Comet
I tapped it in my filler neck housing.
Old Sep 19, 2003 | 01:26 PM
Davidov's Avatar
In that case, there is no need for an adapter. Since the sender has thread on it, just thread a hole in the water pump according to that size.
My sensor's threads were 10mm with a 1.0 thread pitch.
I used a 3/8ths drill bit to start the hole, then threaded it with the said threader size.
Old Sep 19, 2003 | 06:55 PM
Digi7ech's Avatar
I break Diff mounts
Well on S4's I know there is already a bung behind the alternator and between the Thermostat and water pump.
It is already threaded because it was meant for the Electric secondary fan.
Both of my 88 NA's didn't have it so I just removed the plug which did nothing and installed the Autometer Electric gauge.
It worked fine in that location.
Old Sep 19, 2003 | 07:13 PM
Digi7ech, direct bolt size and everything?
Old Sep 19, 2003 | 10:59 PM
Cheers!'s Avatar
Former Rx7 *****
silver aren't you using a S5 block on your TII swap?
if so like the post says it should thread right in (greddy sender)
so get a Y connection with the same threads, and have the stock thread to one outlet and the greddy to another outliet.
presto.
Old Sep 20, 2003 | 12:07 PM
Yes. I have a freshly rebuilt, street ported s5 Block and Water Pump and It's Housing.
I removed both the stock Water Temp Sender Unit and the Accessory Sensor behind the Water Pump Housing. Both to no avail. The Greddy Sensor does not even grip the threads.
I would but I need sizes. Every attempt has resulted In fittings that were Brass, which I'm reluctant to use.
Old Sep 20, 2003 | 05:33 PM
Cheers!'s Avatar
Former Rx7 *****
what is wrong with brass?
Old Sep 21, 2003 | 03:02 AM
I've acquired the fittings that come with the Autometer Water Guages. Of the 2, the bigger one Is a hair to big.
Home Depot/Brofasco will be expecting me soon.
Old Sep 26, 2003 | 10:14 PM
So much for that. I found a brass fitting that fits the Greddy Sensor. The other end of the fitting slides Into the former auxilliary sensor slot (at the Water Pump - below Water Thermo Sensor). At this point, I may just JB Weld the fitting Into place.
Old Sep 26, 2003 | 11:04 PM
Cheers!'s Avatar
Former Rx7 *****
JBWELD =
btw how did you exceed my post count that much? wtf?
i need to do more whoring
Old Oct 2, 2003 | 06:37 PM
Digi7ech's Avatar
I break Diff mounts
ummm a little late for my reply but I had an autometer guage.
I t needed an adapter. So I went to checker and got the adapter kit for AUtometer guages. It was just a bunch of brass adapters which I probably could have gotten from Home Depot but it was 1 in the morning at the time.
Old Oct 2, 2003 | 07:12 PM
Originally posted by Cheers!
JBWELD =
Moderating and letting off FD Alternators sure upped the anti.
Yeah. I went to both HD and Brofasco to no avail. I've since opted to use the Autometer adapter (smaller one) and just JB Weld It. It looks clean and I'm sure It will hold.
_Tones_
May 25, 2021 05:37 AM
24seven_dada
20
Nov 10, 2018 12:03 PM
Ian_D
Oct 14, 2015 12:31 PM
msilvia
15
Sep 11, 2015 12:13 PM
