screeching during auto-x, good or bad?
Old Sep 8, 2003 | 02:39 AM
spikej's Avatar
Hi there, looking into auto-xing. Understand the concept of keeping momentum and smoothness but in a stock FD with street tires, screeching during a turn, does it indicate that you're near the limit of the traction or is it actually slower going around the corner than without the tires screeching, assuming not a 4-wheel slide? just curious, bill
Old Sep 8, 2003 | 08:51 AM
DamonB's Avatar
Screeching is honestly a trait of a particular tire and in itself is no indicator of grip. The "feel" of grip is due to the slip angle of the tire. Basically the load through the suspension builds due to the grip of the tire and actually drops very slightly at maximum grip. Once that point is exceeded the tire very quickly begins to slide.
FWIW street tires have deep, less stable tread and therefore do tend to squeal some when they are at maximum grip. They also tend to squeal when the car is spinning in circles
The feel of a tire's grip has nothing to do with the sound, but you can use the sound to go along with the feedback you receive through the steering wheel and chassis to help inform you of what the car is doing.
Old Sep 8, 2003 | 10:04 AM
redrotorR1's Avatar
LS6 Convert
Squeal not squall. Hearing the tires squealing as you make transitions is not bad .... and as Damon pointed out, some tires just plain ol' howl when pushed at all. However, the deafening screech from coming in way too hot into a corner ... that's bad. Usually an indication of the tire pushed beyond its limit of adhesion and turning capability.
Grip driving is actually faster, at least in auto-x, when the tires don't make as much noise. Again, keep in mind the street tire type and tread depth factor in quite a bit too.
Old Sep 8, 2003 | 02:38 PM
TailHappy's Avatar
Addicted to Track
Or as an instructor explained it to me, you want to hear them "sing" and not "scream". When they're just starting to make noise is supposed to be optimal for a street tire, but if you hear the screaching like you hear when someone's locked up their tires and about to rear-end somebody...you've gone too far! ;-)
Old Sep 8, 2003 | 06:29 PM
88IntegraLS's Avatar
Displacement > Boost
I agree; my best times in my short autox career have been with my tires singing in every cuve.
Old Sep 8, 2003 | 07:59 PM
Silkworm's Avatar
Has been.. hangin' around
That is such a cool looking front end 88 Looks good!
PaulC
Old Sep 8, 2003 | 11:08 PM
spikej's Avatar
Thanks for info. My next question is, when you come to a turn you should brake late but should you have all your braking done before you start turning the wheel and have your foot on the throttle when your actually turning? otherwise wouldnt your rear slide out if youre still braking while turning. tia bill
Old Sep 9, 2003 | 02:45 AM
rynberg's Avatar
You are talking about a technique called "trail-braking". You are correct, that as a beginner, you should do all your braking in a straight line and then turn in. However, in my limited track experience so far, I have found that for the really tight low speed auto-x corners, that a little trail-braking helps the car turn in. It can get you into trouble though.... and I don't recommend doing it in faster corners until you are more experienced (advice I'm trying to follow myself).
Old Sep 9, 2003 | 04:06 PM
crazysuprakid's Avatar
An instructor once said "A squealing tire is a happy tire." In my limitied experience braking while turning is bad, and late apexing(turning in too late) is bad. But who knows what'll lead to you turning better times.
Old Sep 9, 2003 | 05:01 PM
rynberg's Avatar
Late apexing is actually better for novice track drivers. The reason being that you are much less likely to get into trouble applying power coming out of the turn.
Old Sep 9, 2003 | 07:26 PM
I have to trail brake pretty hard to get rid of my Integra's large amount of understeer. I hate that car for anything but daily driving. Time for me to finish the FC.
And thanks Paul. Yellow is a righteous color.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
JZW
3rd Gen General Discussion
29
Dec 21, 2016 11:23 AM
bb6guy
Aug 12, 2015 03:29 PM
