Anyone using 'tall' oil filters?
Old Aug 19, 2003 | 04:58 PM
mwpayne's Avatar
Admitted 'rexaholic'
I don't know, maybe it's just me, but I like the taller oil filters better than those short, squat ones. Talls are easier to get off, too.
Anyone use a brand of 'tall' filter?
Old Aug 19, 2003 | 05:13 PM
Rx7carl's Avatar
Airflow is my life
I do. the filter for an RX4. Getting harder to find though.
Old Aug 19, 2003 | 06:58 PM
wwilliam54's Avatar
it WILL run
have to check em out
but my short mobil 1 does fine
Old Aug 19, 2003 | 07:15 PM
setzep's Avatar
I use a "tall" oil filter, holds a quart of oil and filters down to 10 micron.
Old Aug 19, 2003 | 07:27 PM
wwilliam54's Avatar
it WILL run
nice setup
wwilliam54's Avatar
it WILL run
nice setup
Old Aug 19, 2003 | 07:32 PM
setzep's Avatar
thanks
Old Aug 19, 2003 | 08:26 PM
Rx7carl's Avatar
Airflow is my life
Showoff! I use a purolator. Bigger filter means more surface area, and less bypass when cold. Think about it.
Old Aug 19, 2003 | 08:32 PM
RotorMotorDriver's Avatar
Seven Is Coming
Hmmm...Overkill? Haha, just kidding man, but why did you have to go and show off like that. It makes us poor folk feel bad .
Im with Carl though, I use a Purolator, but just the stock RX-7 replacement size.
~T.J.
Old Aug 19, 2003 | 08:47 PM
anthrax's Avatar
Heck Yes!
Stock Mazda oil filter works fine for me $6.00 and does a great job
Old Aug 19, 2003 | 09:23 PM
setzep's Avatar
I did that cause it was all free (now I'm really a bastard) But really... the bigger the filter the more media area you have to filter and less pressure drop in the system. Also I wanted all the oil to get filtered as it passes through the engine instead of just the stuff that sees the e-shaft.
Old Aug 19, 2003 | 10:03 PM
mwpayne's Avatar
Hey Carl, what's the part # of that purolator filter?
Old Aug 20, 2003 | 08:06 AM
Rx7carl's Avatar
Airflow is my life
I'll post later when I get home.
Old Aug 20, 2003 | 10:18 AM
aGoGo's Avatar
Setzep:
Where are you in MN? I am in St Cloud, I can see 1st gen here and there on 94 when I go to the cities, do we have a car club around here? If there is, I'd like to join one. Nice setup!
Old Aug 20, 2003 | 02:54 PM
Rx7carl's Avatar
Airflow is my life
Who rated this thread???????
The Purolator number is L20073
Old Aug 20, 2003 | 04:33 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Anyone noticed how THIN the metal on the Purolator filters has gotten? I can't put one on with my oil-filter wrench without crushin' the damn thing. I'm using a FRAM filter right now, just because they're sturdier.
But I'll probably switch to a NAPA Gold filter next oil change.
Old Aug 20, 2003 | 04:51 PM
setzep's Avatar
?A?i]Originally posted by aGoGo [/i]
Setzep:
[/QUOTE]
I'm in the southern metro area. There is the North Star Rotary club. I'm not a member but do a search and you will find out how to join.
Old Aug 20, 2003 | 06:07 PM
inittab's Avatar
I read your email
I've been using WIX filters. They seem to be built well. Heck WIX invented the spin-on filter. Anyway, I went to their website and they recommend the same filter for both the RX-4 and RX-7.
Part Number: 51356
UPC Number: 765809513563
Style: Spin-On Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Old Aug 20, 2003 | 06:31 PM
The_Dude's Avatar
TT 1st gen ? We'll see !
I have been using the stock mazda one. I fugure they had to know what they were doing when they invented that. But I also used a fram for a little while. I was quite satisfied too because they're easy to take off.
I'm not ready to say that bigger filter are necessarilly better ... u can only get a certain amount of oil in and out a a time NE ways !
Old Aug 20, 2003 | 07:16 PM
Rx7carl's Avatar
Airflow is my life
FRAM???? Besides your not supposed to put it on with a wrench, thats for removal gorilla man!
Read this and lets have a nice discussion.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old Aug 20, 2003 | 08:57 PM
setzep's Avatar
Wow, thats a good reason to choose a oil filter...
Another smart one...
FD7KiD
15
Feb 26, 2021 10:12 PM
The1Sun
Mar 18, 2018 11:08 PM
20B Forum
13
Sep 4, 2015 06:54 PM
FD7KiD
Aug 17, 2015 11:50 PM
