I am wondering about something
Old Aug 19, 2003 | 01:50 AM
Sprockett's Avatar
Former Rotorhead
I have been noticing an annoying problem lately....my car just doesn't seem to want to be as fast as it should be. I just recently thought about what might be causing this, and came up with this idea...
Some of you know that I made the biggest mistake of my life and took my car to a dealership to have my engine replaced. Long story short, it took them 4 months and they still didn't have it done anywhere close to right. Anyway, I know they put in new spark plugs with the engine, but I am wondering if maybe they used the wrong plugs. I mean, they replaced some of my vacuum lines with old braided lines they had lying around, so I am thinking they just replaced them with whatever they had at the time.
My question is, what would the symptoms be if they used an inferior plug, how would I check to see what kind of plugs they used (does it say on the plug anywhere?), and given the mods below, what kind of plugs should I have?
Here are my mods:
Blitz intake
Pettit downpipe
3" cat back
(my list is so small )
Thanks,
Tyler
Old Aug 19, 2003 | 01:53 AM
rynberg's Avatar
We can't help you if you don't have a boost gauge.....but the plugs are easy to check and replace from below.
Get a boost gauge, even a cheapo mechanical one will be good enough to at least do some diagnosing.
Old Aug 19, 2003 | 02:03 AM
Sprockett's Avatar
Former Rotorhead
too true....I almost forgot about that damn little thing.
Old Aug 19, 2003 | 02:09 AM
duboisr's Avatar
Do not waste you time guessing about what the dealer did . Get new plugs and put them in or find someone you that you trust to help you put them in and check out any other problems . Then turn up the radio and ride .
Old Aug 19, 2003 | 02:30 AM
Sprockett's Avatar
Former Rotorhead
Just ordered Boost gauge.......
Still waiting for someone to tell me what plugs I should use
Old Aug 19, 2003 | 02:41 AM
Sprockett's Avatar
Former Rotorhead
To install that gauge,
I just have to hook a vacuum line to the blocked off outlet on the UIM, run it along the firewall to the driver's side, put it through the little hole there, run it up and mount it to the A-pillar using the single pod I got, too - right?
Old Aug 19, 2003 | 02:56 AM
teamstealth's Avatar
Ozone Depleter
yup
Old Aug 19, 2003 | 02:57 AM
rynberg's Avatar
For a mechanical gauge, that's about it. You will also want to hook up the lighting for it. Use the wiring for the ashtray or headlight retractor switch.
The plugs should be BUR7EQP for leading and BUR9EQP for trailing. NGK plugs are fine.
Old Aug 19, 2003 | 03:30 AM
NorthwindHost's Avatar
Actually running all 9's are fine as well. I believe they run cooler too.
Old Aug 19, 2003 | 09:46 AM
ZeroBanger's Avatar
HEY WATCH IT I HAVE A CHEAPO MECHANICAL GAUGE THANK YOU VERY MUCH.
Ok Tyler, sorry for shouting I was just mad.
how does a dealer take 4 months to install an engine? Dont take your car to a dealer for anything. Do the spark plug change, install the cheapo mechanical boost gauge and go home happy.
Old Aug 19, 2003 | 09:55 AM
matty's Avatar
Re: I am wondering about something
you need a rb front air dam to make your car run to its full potential
Old Aug 19, 2003 | 10:18 AM
rynberg's Avatar
Haha, you just have Defi envy.....
Old Aug 19, 2003 | 10:32 AM
ZeroBanger's Avatar
Nah, Defi looks better during the day, I'll give you that, but the Autometer looks better at night
Old Aug 19, 2003 | 11:16 AM
dubulup's Avatar
development
I'd rather have a back lit gauge at night...
autometer here.
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
