Oil cooler removal, what socket?
Old Jul 31, 2003 | 08:03 PM
mwpayne's Avatar
Admitted 'rexaholic'
Anyone happen to know the right socket to take the big oil cooler line off the engine block? A 15/16 sort of fits, but not snug enough to remove it. Must be a big-*** metric of some kind.
Thanks!
Old Jul 31, 2003 | 09:24 PM
Swolbynos's Avatar
Newb
just use an adjustable wrench, that worked for me. i think it is like 20mm
Old Jul 31, 2003 | 09:36 PM
White84SE's Avatar
U sUx0rz @ THe IntaRwEB!
It's a 25mm...
--Danny
Old Jul 31, 2003 | 10:16 PM
mwpayne's Avatar
Thanks, now off to sears!
Old Jul 31, 2003 | 10:35 PM
Swolbynos's Avatar
Newb
well like i said i used an adjustable wrench so it was a guess...
Old Jul 31, 2003 | 10:48 PM
RotorMotorDriver's Avatar
Seven Is Coming
You need one wrench to hold the fitting in the block, and another to turn the line, in case you didnt notice...
~T.J.
Old Jul 31, 2003 | 10:59 PM
mwpayne's Avatar
Right, two adjustables for the front line. I was having trouble with the rear one, a 15/16 was rounding out the bolt. I'll pick up a 25mm tomorrow.
Old Jul 31, 2003 | 11:10 PM
White84SE's Avatar
I used an adjustable wrench on mine, too.. but it's max width was 25mm and I had it adjust the whole way open.. test fit the socket before you take the tag off.. my wrench may have been off and I don't want to screw ya out of $7...
--Danny
Old Jul 31, 2003 | 11:30 PM
Siraniko's Avatar
RX for fun
buy a cheap *** 7/8 and grind it down to make a sure fit plus an adjustable.
Old Aug 1, 2003 | 12:34 AM
Rotary13B1's Avatar
Now thats a thinking man!
Old Aug 1, 2003 | 08:16 AM
82transam's Avatar
Never Follow
Are you referring to the banjo bolt that holds the long cooler line towards the rear of the engine? If so its a 23mm.
Old Aug 1, 2003 | 01:06 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
no its 24mm i've got that and a 25mm... its cheaper if you get the head that pops into the rachet... the 25 is for the hose and the 24 is for the fittings... i assume that this is a GSL-SE...
Old Aug 1, 2003 | 01:48 PM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
Mine came off with a 24mm and an adjustable. Had to use a 'persuasion' bar to free mine. Total PIA.
Old Aug 1, 2003 | 02:23 PM
mwpayne's Avatar
Yes, its the one big line on the rear of the engine.
Gues I'd better pick up a 23, 24, and a 25!
Old Aug 1, 2003 | 08:07 PM
mwpayne's Avatar
*Update..it's the 23. I know this because I CAN'T FIND ONE! Sears has the 21, 22, 24, 25.
Old Aug 1, 2003 | 08:49 PM
82transam's Avatar
Never Follow
Sears doesn't have a 23mm socket unless you buy a whole set, I just bought a 23mm combo wrench and used that. Not sure about SE's, but the lines on non SE's have a 26mm end on the line and the aformentioned 23mm for the banjo.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
