On the 88' t2's, are the REAR brakes 1 or 4 piston?
Old Jul 30, 2003 | 05:28 PM
mrb63083's Avatar
Question On the 88' t2's, are the REAR brakes 1 or 4 piston?
just like it says? need an answer asap thanks.
Old Jul 30, 2003 | 05:31 PM
Rxmfn7's Avatar
Do a barrel roll!
Old Jul 30, 2003 | 05:35 PM
mrb63083's Avatar
****, thanks
Old Jul 30, 2003 | 05:38 PM
RXciting's Avatar
GrapefruitRacing?
all rx-7's come with stock 1 piston calipers.. the difference is some have vented rotors
Old Jul 30, 2003 | 08:13 PM
RETed's Avatar
single, piston - floating
-Ted
Old Jul 31, 2003 | 02:30 AM
WTF
what does floating mean?
Old Jul 31, 2003 | 02:34 AM
OC_'s Avatar
OC_
I'm bastardizing my car!
its means the disk is not hard bolted to anything.. it can move in and out a little. its supose to be easier on the pads i think. i didnt know our rears were floating.
Old Jul 31, 2003 | 06:07 AM
RoninAutoBoX's Avatar
Old School Rotors
It means that the caliper itself will move in order to apply pressure on the rotr. With a 4 piston setup, the caliper is just bolted in place, and the body never moves, the pistons do, in order to compress the rotors. With a floating caliper setup, one piston sqeezes on one side, pulling the other side of the caliper against the rotor as well at the same time.
Old Jul 31, 2003 | 08:41 AM
n4ji's Avatar
SPQR
I wonder why Mazda didn't put atleast a 2 piston on the rear caliper since the front had a 4? I know the ratio of front brake usage to rear usage is about 60:40, and I know the 300zx has 4pt in front and 2pt in back and those things can stop on a dime..
Old Jul 31, 2003 | 09:04 AM
Rxmfn7's Avatar
Do a barrel roll!
You dont really get any more clamping force with multiple piston setups. It basically just makes sure that pressure is evenly distributed across the entire pad, for better wear and breaking characteristics. The rear pad isnt nearly the size of the front one, so 1 piston caliper should do the job just fine. And I think my FC would out-break a 300zx any day....
Old Aug 1, 2003 | 02:34 PM
RETed's Avatar
300Z stopping?&nbsp You gotta be kidding me, right...
-Ted
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
