Any problems with tapping the water pump housing?
Old Jul 30, 2003 | 06:29 AM
adamlewis's Avatar
Back from teh deadly!
I want to put a sensor in there for the Haltech. The only thing Im afraid of is metal shavings getting into the housing. Can I tap it and then just run some water through the housing and turn the pump by hand to try and get them all out?
Old Jul 30, 2003 | 07:36 AM
Fingers's Avatar
Aside from having to pull it, no
Old Jul 30, 2003 | 08:47 AM
White_Seven's Avatar
FC 2 NV
It's really not that much work or time to yank the housing, so I'd do that if I were you.
Old Jul 30, 2003 | 10:16 AM
MURX's Avatar
None at all. Kinda a pain if thats all you are doing, but if you had the car all apart, could have tapped done in 10 mins.
Old Jul 30, 2003 | 10:51 AM
silverrotor's Avatar
Can't you use the pre-existing Sensor (not sure on It's purpose. Aux fan?) found below the Water Temp Sensor? I say this b'c your going stand alone.
Prior to my conversion I had It tapped on the Thermostat Housing. But now, I'm going to take advantage of the Water Pump Housing with It being off and tap there.
I'd take off the Housing. I'd hate to have even a sliver of shavings circulate and ultimately clogg up the Radiator Core.
Old Jul 30, 2003 | 11:01 AM
Fingers's Avatar
I asked in another thread but didnt get a valid response. How hard is it to pull the water pump? any complications? How long does it take? I just want to take it off to inspect the impeller.
-Ross
Old Jul 30, 2003 | 11:10 AM
Simple. Actually. Once the Main Crank Is out, you'll have to take out the additional Pulley. From there, you can remove It.
I'd Imagine your Impeller Is fine. It's the Inner bearings or/and seal that would bet the culprit.
Do you have WP or related problems Ross?
BAAAAMMM!
Old Jul 30, 2003 | 03:08 PM
adamlewis's Avatar
-Ross
4 bolts for the main pulley, and 4 nuts on the water pump.
Old Jul 30, 2003 | 03:10 PM
adamlewis's Avatar
The only sensor I have is the water thermoswitch. Its too small to accept the sensor that came with the Haltech, so Im just gonna drill/tap it larger.
Old Aug 23, 2003 | 10:12 PM
just change the hose tape should only be temp.
FD7KiD
15
Feb 26, 2021 10:12 PM
sherff
Feb 24, 2019 12:09 PM
FD7KiD
Aug 17, 2015 11:50 PM
