Can't find the pills need help!
Old Jul 4, 2003 | 09:57 AM
MR_Rick's Avatar
Planning my come back
I'm working on installing the home depot boost controller and I took out the vacum lines that are suppost to have the pills, they are not there! The turbos got replaced a year ago so I'm guessing that the pills didn't get put in. What will happen if that the case? what will happen if the pills are there and I start tunning the valves with the pills in the location of the 94+ that are in the turbos (which I don't know where)? When I got the car I had boost problem (8-4-4) got that fix by adding a DP. Then my boost was 12-8-12~14. need help asap. Thanx
Old Jul 4, 2003 | 10:22 AM
Arubin's Avatar
Hey. I have the same boost problem. And all hoses were checked etc. But could not diagnose the problem.
https://www.rx7club.com/forum/showth...hreadid=202324
How did you figure it was the precat?
Old Jul 4, 2003 | 10:26 AM
MR_Rick's Avatar
I just took a wild guess that seem to make sence. a DP is not a bad idea. It will lower your under hood temperature and make the car run easier. It wasn't just the DP I also had a bad vacum line and a leak in the pipe that goes from the IC to the TB, that was crack right at the seam of the collar that goes in the TB.
Old Jul 4, 2003 | 11:09 AM
MR_Rick's Avatar
anyone?
Old Jul 4, 2003 | 11:28 AM
Mahjik's Avatar
Mr. Links
http://www.autosportracetech.com/RX-7/faqs.htm#Pills
It's possible that you don't have pills, but that the nipples are the restriction on your car (which are on the later FD's).
DerpyToast
14
Nov 23, 2024 05:19 PM
Ian_D
Oct 14, 2015 12:31 PM
rafgonz
Sep 7, 2015 06:36 AM
Apoc3D
Sep 5, 2015 10:24 AM
