Boost problem has Rick's rotary stumped!!
Old Jul 3, 2003 | 09:54 PM
Arubin's Avatar
Hi people, here's the story. My FD's first turbo makes just 8lbs boost, the 2nd only 4lbs.
Rick removed the upper plenum, checked operation of vacuum solenoids, hoses, checked for restrictors in turbo lines, checked actuator operation at exhaust manifold, replaced vacuum lines that were kinked, substituted another computer to check boost, checked the check valves and can't find the root of the boost problem. No problems with the turbos. He's stumped and recommends using a HKS EVC IV to over-ride the stock boost controls.
Anyone has any had a problem like this before? If you guys are in touch with any of the rotary tuners, please ask them too. I'm going to get the boost controller but would like to know what's the problem.
By the way, anybody selling a used HKS EVC IV?
Old Jul 3, 2003 | 10:13 PM
pomanferrari's Avatar
Click here: http://www.autosportracetech.com/RX-...oting.htmPrint this out, go through everyone of the tests given here.
My impression is that there is a leak in your vaccuum/boost lines or you're missing the pills in the turbos.
Old Jul 3, 2003 | 10:14 PM
http://www.autosportracetech.com/RX-...leshooting.htm
Old Jul 3, 2003 | 11:09 PM
johnchabin's Avatar
Verify both lines to the TCA are working after transition. Vacuum on one, pressure on the other.
Old Jul 3, 2003 | 11:16 PM
Arubin's Avatar
I forgot to add that Rick said to boost the 2nd turbo to higher than 4psi, after 45000rpm, release and step on the accelerator again.
Old Jul 3, 2003 | 11:20 PM
Dalen's Avatar
CHECK YOUR CLAMPS! honestly.. it happened to my friends FD.. like he had very little boost if not none and all it ended up being was that the clamps lost their tightness.. i also am getting shitty 2nd and not the greatest primary.. but ya.. sometimes its something stupid thats costs only 5 dollars
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
C. Ludwig
Jan 30, 2019 06:31 AM
